0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | I'm thinking of having Kansas Kustoms split my 235 exhaust manifold so I can use my heat riser. Too many lines messing up engine with water heat IMHO. I'm going to use an older 216, 2x1 intake manifold. I've been told that the 216 and 235 will not match up as the bolt holes where the two intakes connect (heat chamber) are different with the 235 being farther apart than the 216. Can I get these to mate up or must I go with water heat and a plate? Thanks
| | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | It's true that the 216 and 235 heat chambers are different sizes. Consequently, it is not possible to bolt a 216 intake manifold to a 235 exhaust manifold. If you want to use the 216 2x1 intake you have and want to bolt it to a split stock exhaust manifold, you will have to find a stock 216 manifold to split.
Luckily, it is not that difficult to find stock 216 exhaust manifolds at reasonable prices. You might be able to find one on Ebay or here in the swapmeet. There might even be a few fellow 'bolters that have been tripping over one in their garage and are ready to get rid of it.
Good Luck | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | If the sizes are different then you can tell by measuring the bolt hole distances, if an old intake manifold was for a 216 or a later 235. Pretty good information for all of us to have for buying at swap meets, e-bay etc. Can somebody measure the heat chamber mounting holes (on center) , cross corners, of a known 216 and of a known 235? This is important since we also need to machine the ports if we buy a 216 to use on a 235. Knowing what it's really for will avoid any surprises later. Swap meet buyer: " Hey what's this fit?" Swap meet seller "What da ya got?" :-)
