5 members (Stovebolt48, Eisenholtz, Hotrod Lincoln, 2 invisible), 52 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#1520243 10/03/2023 11:07 PM
Hello all,
I'm fairly sure the source of my 2nd to 3rd gear grinding was due to either the synchro not being correctly pressed into the main gear or I didn't set in the retaining ring correctly when I rebuilt my 3speed last year. Not sure what the correct terminology is but I'm meaning the ring that sets into the synchro. The two notches have some damage due to shearing (most likely my fault). Is this component still available or would a machine shop be able to have the notches repaired enough to suffice for my pickup that gets very light and infrequent use?
H Online: Content
Unfortunately, it looks like you've got an expensive paperweight now. That one's beyond help. Which 3 speed are you working with?
Donald S.
Donald S.
I have one of those I got off eBay recently if you are working on a SM318 trans? Then I found the whole synchronizer drum with that part included on both ends of the drum. Let me know by DM?
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
I was told it is a ‘40 3-speed. Not sure of the exact model.
There is an NOS one on GM# 591087 available today.
May need to be quick as the ad says auction time left is only about 7 hours from now.
Hope you can get what you need! smile
~ Dan
1951 Chevy 3 window 3100
Wow, I see that. Looks like what I need. Thanks!!
