1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I haven't crawled under it yet but the bed of my 54 is leaning/sitting lower on one side. I don't think it is just the bed. Bumper seems low also so i think the whole frame is low. I am planning to lift the bed off to replace the bed boards. While I have easy access, what should I look at?
| | | | | Joined: Mar 2014 Posts: 4,484 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,484 | Hi Dave, There will be some wooden spacers between the frame and the bed...usually they are simple pieces of oak about 3 inches square into which a hole has been drilled in the center. If one of those breaks, it usually cracks at the hole and then it can fall out...leaving one side of the bed (usually one corner, really) leaning downward. If the bed hasn't been hit nor damaged I'd look there to see what's happening. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2009 Posts: 5,848 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,848 | Dave , Just a slightly different suggestion than Jon G, more in line with the topic of this forum. A lower level/lean on one side that includes your bumper may be a sign you have a rear spring and/or shackle problem. Check the shackle to be sure it's still attached to both the frame mount and rear spring eye and has same stand-off as the opposite side of the truck. Check the spring for a loss of arch compared to the other side and for damage/breakage at the spring eyes on either end as well as possible cracked/broken spring plates. Also check the axle to spring mount at the spring and spring to frame mounts for cracks or signs of movement. Oh yeah, might as well check the shocks and shock mounts for good measure.  Snap and post a few pictures of the truck rear suspension (both springs/sides) and that may lead to more info. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | I would start by parking on a flat surface and checking things with a tape measure. I don't trust my eyes 100% anymore. Check frame to axle on both sides, bumper to ground, ...
@Jon: He has a 54, so no wood spacer blocks.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Well, it is not good news. I had the truck in this morning getting new exhaust. I was able to look under at the frame. Right at the rear shackle where the leaf spring connects to the frame it is rusted pretty thin and the frame buckled right there. The rest of the frame seems pretty solid. I am hoping when I pull the bed off and can straighten it at that shackle and weld in a piece of reinforcement. I just had a fairly heavy load of concrete on the truck over the weekend. The so called straw that broke the camels back.
| | | | | Joined: Sep 2009 Posts: 5,848 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,848 | Sorry to hear that news Dave.  Good luck on the frame and spring mount repairs.
| | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I have a 49-3100 and one side was leaning. One of my friends told me if you were that old you would be leaning to!!! I put four new springs on and problem was solved. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I don't think I am going to have any problem straightening the frame. I just hope I can reinforce it enough to be serviceable. It must be pretty thin in a couple places. Just for the heck of it I grabbed the back corner of the bed and lifted it up. I was able to pull it back up to where it should be and it stayed. Clearly needs a little strengthening. | | |
