| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Does anyone know what the stock E-brake set up was on a 51' GMC 640? I have air brakes but can't find anything that looks like an E-brake. I think I need a manual.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Clutchheadstew,
Is there a spring brake unit piggybacked on your service brake chamber?
Stuart | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Clutchheadstew, In those days spring brakes were rare, I suspect it was probably equipped with a driveshaft parking brake, probably a "Tru-Stop" either a single or double sided type. Is there something on the driveshaft or the tranny or the auxilliary that looks like a large disc brake rotor? Hope that helps. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Hey guys, I found a new in the bag 5000 Dual control valve kit behind the seat this afternoon. looks like a valve you can cut in to your air system and mount on your dash for park and emergency situations.This is what I'm used to seeing for E-brakes on air. 3B, nothing on the shaft,first place I looked. I also found out what that monster engine is 3B..... :mad: it,s a 534 super duty F**D in my first big GMC :hammering: what was someone thinking!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Clutchheadstew, I happen to know a guy who may be able to supply a proper engine for that truck, hope that helps. [P.S. how are you ever going to get the stink out of it?] | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Hey Bobb, I E-mailed you this morning concerning a engine change out. I don't think they make any thing to clean up this mess except putting something GM in it. I thought it was the ferret under the seat that I was smelling
