| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I am building a stand/dolly to hold the trans while i work on it. I thought it was in neutral but when i turn the shaft the rear drive turns. I tried shifting it and goes rev, 1, and2 cant get the arm to move to the 3-4 position. could something be jammed or out of alignment in side? hoping to take the top off once the dolly is done. will there be any suprises when i do that? springs popping out or stuff falling inside? gona get in touch with novak trans and see if they have new gaskets and the front bearing shaft that loooks broken. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If you're trying to shift the transmission with it sitting on the floor , that can be hard to do sometimes, you might need to rotate the input shaft while trying to shift it into gear. Mike B  | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I tried turning the shaft. no luck in 3-4. what concerns me is when it is in the neutral position the input still drives the out put. should have the top cover off this weekend if no rain. that may show the problem. | | |
