4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#1519330 09/27/2023 2:24 AM
On the Rochester B carb, is there a gasket between the throttle body and the Bakelite spacer ?
49.3600 #1519334 09/27/2023 2:48 AM
Insomniac
Insomniac
No gasket required and I don't use one. However, some people like to put a gasket there. If you do, make sure that the gasket does not block the carb's vacuum port.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
49.3600 #1519348 09/27/2023 11:31 AM
Thank You!
