1 members (Steelonsteel),
79
Mod | | | Forums66 Topics128,095 Posts1,056,490 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2022 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 9 | Getting ready to move a 1941 1/2 ton chevy panel out of the barn and into shop. It's sitting on a dirt floor with 4 flats, best advice or way to get it onto a trailer? Thoughts were to slip on some cheap tires to get it rolling, then wench onto trailer. Is that a good idea? Options for modern tires that would fit, just to get it on the trailer? Thanks! | | | | | Joined: Oct 2021 Posts: 6,879 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,879 | Try to pump up the tires. You might be surprised.
What size rims? 16"x4.5"?
There's no point in buying 4 new tires unless you plan on keeping and using them. Tires are too expensive these days and there's no such thing as a cheap tire these days unless $100 each is cheap to you.
215x85 R16 is the correct modern size for 16"x4.5" rims.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | A 41 would have 16x4 rims, which are pretty narrow for 215-85R16 tires. An option to move it would be to borrow some used rims and tires. Try airing them up like Otto suggested, or get some new tubes if they won't hold air. That assumes the tires aren't dry rotted, but if they are, don't try to put air in them, or if you do, at least keep the pressure just high enough to make them round if you value your eardrums.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | peete17, Kevin is right about the original rim size of just 16" x 4" wide. You can however bolt up some later 16" x 4.5" wide rims (used on 1/2 Tons up through 1955) if you can find them with some still round tires as a temporary solution to putting some rolling stock under it just to get onto the trailer and home. This is all assuming (yeah I know what that can mean - lol) that you are just looking for a temporary solution to get it home.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2022 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 9 | Good point tires aren't cheap:) I'll have to take a closer look and see if we can put some air in them. | | | | | Joined: Nov 2022 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 9 | Is there a modern tire that fits the 16x4 rim? | | | | | Joined: May 2022 Posts: 28 'Bolter | | 'Bolter Joined: May 2022 Posts: 28 | Hi Peete17- A 600 X 16 tire will fit on the 16 X 4 rims.
Mike
1939 1/2 ton Chevy
| | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | The 215/85R16 will fit, but they're designed for a rim width of 5.5 thru 7. The tread width is 6.2 inches, and they're 8.5" wide at the widest part. But even that size is nearly $200/tire. I'm not finding a narrower tire than a 215 on Tire Rack that would fit a 4x16 rim. Except for temporary spare tires which you don't want.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2022 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 9 | Not sure spare tire would be cheaper, but couldn't that be used short term? Spare would fit better on 16x4 rim right? | | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | Not sure spare tire would be cheaper, but couldn't that be used short term? Spare would fit better on 16x4 rim right? Yeah, those temporary spares would fit better on the narrow wheel, but are just as expensive as REAL tires. Visit a wrecking yard and see if they have some chevy 6 lug wheels and tires that you could bolt on. Probably cheaper than buying new temporary tires that you really can't use. Maybe there's a Bolter near you who would loan you a set of wheels/tires to use. Try an ad in the Swap Meet.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2022 Posts: 9 'Bolter | | 'Bolter Joined: Nov 2022 Posts: 9 | | | |
