4 members (Otto Skorzeny, Rustnut, 78buckshot, DadsFirstPickup), 197 guests, and 6 robots.
Topics128,108
Posts1,056,236
Members48,437
#1513653 08/20/2023 12:24 AM
'48 3800 moves but when jacked up one wheel can be moved by had one too tight to move
Guessing it was parked with parking brake on
Any ideas on how to get drums off
Can I release something on the back so shoes and all come off
Have not tried yet but this is not going to be fun
Jack,
If you haven't already, read Chapter 5 of the 1948-51 Shop Manual as it applies to your 1 Ton Huck brakes.
There are removable plugs (could be metal or rubber) near top back side of the rear backing plates that you must remove to get a flat bent brake adjuster tool into the inner drum area and back off both adjusting wheel caps on the wheel cylinder. See Figures 2, 5 & 25 in Chapter 5 for pictures that show the wheel cylinder and adjusters to know where to look on your truck.
You will need to back those off to release the brake shoes away from the drums. If the shoes haven't moved in a substantial time period, you may need to rap on the sides of the drum to cause the shoes to free up from the drum, then proceed with drum removal per the instructions in the Shop Manual.
Before all of this though, make sure you have done what you can to release the parking brake mechanism. You may even need to disconnect the cable clevis on the side that you think is seized up to free up the cable and in drum mechanism.
Let us know how it works out.
Dan
~ Dan
1951 Chevy 3 window 3100
Thank you Dan
Really appreciate it!
And I assumed huck brakes was a 1/2 ton thing
That oldcarmanualproject is a great site
Very helpful
Glad it was helpful! chug
Let us know how the brake work turns out! thumbs_up
Dan
~ Dan
24601
You might find this handy, as well. Its a diagram I made while working on my '49 3804's Huck brakes. The diagram assumes you are seated with the brake mechanism directly in front of you. Hope it helps.
Huck brake adjusting diagram
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John.
Authorized Pest
Authorized Pest
HERE IS the Tech Tip that John posted in the Driveline Tech Tips section that goes with that image.
wave
~ Peggy M
1949 Chevrolet 3804
Sooooo
Please see pic
I don’t see an adjustment slot
I looked in my 58 manual to see what type of brake this is if not Huck thinking maybe a more modern axle or something different RE the dump bed
What am I missing
Pic
Jack,
Your 1 Ton rear brakes have external adjusting bolts, the 2 bolt heads protruding from the backing plate on either side of the brake line.
Below is a screenshot from Pg 5-13 of the Shop Manual that displays the bolts and how they interact with the geared adjusters on either side of the rear wheel cylinders inside the brake assembly. The diagram shows a "cut-away" of the backing plate and drum so you can see how turning the wrench on the bolt causes the adjusters to function.
To release or draw back the shoes, you will need to turn the bolt heads "counter-clockwise" to back off the settings (the description with the adjuster diagram says you turn them "clockwise" to increase drag of the shoes against the drum when setting the adjusters).
Hope this helps clear up any misunderstandings. wink
Dan
1 Ton brake adjuster diagram 1948-51 Chevy Truck Shop Manual.png (203.02 KB, 152 downloads)
1 Ton Huck rear brake adjuster info (from 1948-51 Shop Manual)
~ Dan
Those might be Bendix brakes. The wheel cylinder is on the top and the adjuster is on the bottom. Is there a single slot below the axle tube? Check the figure on this page.
[on edit] Nevermind. Dan has the right answer. wink
Thanks guys
I’ll take a look tomorrow
Jack
The bolt heads with the springs behind them to the left and right of the brake line are your adjustment bolts. If memory serves me they are righty tighty, lefty loosie regardless of which one you are adjusting.
Oops, didn’t realize I was only on page 1. Looks like gdads51 already answered your question.
Ok all adjuster bolts turn but only 1/4 of adjusters inside drum are free and don’t want to break bolts off
One wheel freed up but the wheel that I can’t spin by hand both are stuck
Spraying down but I doubt fluid is getting to where it needs to
Suggestions to get drum off without ruining
Only thing on the back I could release is wheel cylinder
BTW what an excellent idea for adjusting brakes instead of those horrible slots
Of course don’t want to bend up linkages either
I’ve tried push park brake cable back in assuming it had been parked with brake on
The wheel does rotate when I move truck
Jack,
If the wheel you can't spin by hand is at least free enough to allow the truck to roll, all hope is not lost.
I would suggest generous fluid application and gentle persuasion, giving some time for the fluid to migrate inside and hopefully work it's magic.
You may also need to try and give those bolt heads a few raps with a hammer as strikes could cause rust to break free and allow for movement again.
Hopefully some useful suggestions to help the process.
Dan
~ Dan
Good ideas
Thank you
Judicial use of a 2lb hammer around the drum and a like amount of prying with a large screwdriver and a large amount of patience will usually be successful. Good luck.
Roger that
Haven’t gotten the adjusters to release so I’ll try pull the drum
Don’t see where I can get anything in to pry between drum and backing plate
Plate wraps around drum pretty well
How bad of an idea is it to loosen nuts on axle shaft tube so they cover the end of the tube to protect it and put a plate to cover the tube to have something to push against and use a harmonic balancer puller to pull on the flange where the axle shaft bolts to?
What am I missing
If I mess up the drum are they available
Got it
Found a purchase point
Lots of prying and beating
Didn’t swear once
Any suggestions to get brake return spring off/on
Pretty stiff spring
Was there a tool for this and don’t say vise grips
Vice grips wink
Do you have a brake spring tool? A plier like affair with items on the ends of the handles that help remove and install springs.
Jack,
Check out the picture in Figure 36 on Page 5-17 of the Shop Manual.
Those nifty "brake spring removal pliers" can be found just about anywhere, even your local Harbor Freight, if you have one.
Dan
EDIT: Kevin beat me to the punch. thumbs_up
~ Dan
Thank you!
Update
Even with strong hands couldn’t get spring off with spring tool
I’m sure there’s a better set out there with more leverage
Put a vice grip on the hook of spring and used my huge channel lock to squeeze vice grip towards shoe face
Popped right off
Jack,
As has been said somewhere along the way, there is more than one way to get a job done.
Congrats on getting the spring off! wink
On to the next steps, yes?
Dan
~ Dan
Yes sir
More to follow
Moderated by  Dusty53
