9 members (dt235sd, Jon G, Gdads51, mick53, 4tttt8, Leo, Otto Skorzeny, TUTS 59, 1 invisible),
87
Mod | | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2023 Posts: 21 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 21 | Gentleman for the life of me I cannot get oil pressure readings of the Factory or 2 different aftermarket Autometer gauges. The gauge is 0-14 PSI. Engine is quite and runs very smooth ?????????????????? | | | | | Joined: Oct 2021 Posts: 6,955 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,955 | Have you verified that oil is actually flowing out of the tube that goes to the gauge? Maybe there's a clog at the port
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Try putting some air pressure into the gauge port to clear any clogs it might have. It's not uncommon for a 216 to have very low oil pressure, but "zero" is a bit too low. Try disconnecting the gauge line and running the engine for a few seconds- - - -you should get at least a trickle if the oil pump is working. There's always the possibility of a clogged pump pickup, or a stuck relief valve at the pump. Checking both of those problems would require dropping the oil pan.
Has the distributor been removed recently? It's possible to get the oil pump drive tang on the bottom of the distributor shaft misaligned and stop the pump from turning. Jerry
| | | | | Joined: Aug 2023 Posts: 21 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 21 | | | |
