7 members (Steelonsteel, dt235sd, klhansen, Charles in CA, BarryP, Wally / Montana, 37 GC), 139 guests, and 3 robots.
Topics128,142
Posts1,056,782
Members48,454
NJC
Offline
I plan to replace this starter because, while it works when I bench tested it, it doesn't move the flywheel (4 teeth per inch) on the 1956 6 cylinder 235 engine I plan to install. The question I have is do I replace it with original 6 volt starter? Why? I read you can only use a 6 volt starter on the flywheel that has 4 teeth per inch but it's okay to run 12 volts. Please advise. Thanks. V/r, Nick
If your starter spins but it won't turn the crankshaft, all it needs is a new drive gear assembly. If you're determined to replace it, count the teeth on the flywheel. A 139 tooth flywheel needs a 6V starter. A 168 tooth will need a 12V starter. It's OK to run a 6V starter on 12V as long as the engine is well tuned and it doesn't require a lot of cranking. If the engine won't start in 5 seconds or less, tune the engine so it starts easily.
The starter in your photos appears to be a 6V unit, which would be incorrect for a 1956 engine. 12V Delco-Remy equipment had a red ID tag. 6V equipment tags are black. Mid-year 1955, Chevy switched to a 12V electrical system, so your engine would have been factory equipped with a 168 tooth flywheel and a 12V starter. Count the flywheel teeth, as a 6V flywheel and starter might have been installed on a later model engine at sometime in the past.
www.ebay.com/itm/321415511100
