4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
Got my cab back from paint and need to take old cab off frame and put new cab on it. Need to know how many friends i need to make this month. cab will be bare no seat ,no doors no gastank. but engine stillin frame and bed is on also. Think lift and steep over frame to get it off and same to put new one on. any ideas would be appreciated.
If you have an engine hoist you can do it singlehanded. You can rig a 2x6 on the end of the hoist arm and lift it through the foot openings.
Like this:
interesting. wonder if i put eyebolts thru the mount points if it would work. or a 2x4 frame to lift from. Thanks for the idea.
Here’s what my set up looks like. It made setting the cab a one man job even though I had several guys drinking beer and giving me “pointers” as I worked.
Always good to have supervisors. grin
If you mean eyebolts thru the floor, that might work, but the higher the lift point the better, for stability.
The upside down "U" beam that LAJones48 used is overkill IMO, but more stable than my single 2x6.
I know I am cheating, but I just use a 2x10 layed flat on two pads of my lift. I do have to put every extension on the pads to clear the engine.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
I wonder about it tipping. first was gona loop straps thru cab and lift from roof. the old cab is Very rusty and am afraid of ripping the roof of. new cab hate to hurt paint. still thinking of a plan
I doubt it's that rusty that the roof would come off. If it was, the roof would probably be laying on the seat already. Lay some carpet on top of the wood beam to protect your paint under the door opening. You'll notice I put a ratchet strap over the roof to secure things. You could do that with some padding under it. I used that piece of cardboard just under the ratchet itself to keep from gouging the metal. With it supported from the top of the door openings it isn't going to tip. You can adjust the position of the beam to get it level, and it will stay there.
In 1957 a conventional cab weight is given as 650 lbs, this is from the salesman hand book section 12 page 44. The LCF cab is given as 634 lbs.
Since the 58 and 59 cab is very similar the weight should be very close to this.
The cab will not tip using the 2x6 set up, just make sure to have boards attached so the lift boards stay centered. Lifting at the mount points not a good idea.
