Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (klhansen, carbking, 1 invisible), 286 guests, and 6 robots.
Topics128,283
Posts1,058,521
Members48,490
Are the 235, 250, 292 valve covers interchangeable? Can I put a 235 or 292 valve cover on my 250?
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior
'66 Chevy C10
'03 Chevy Silverado 1500 HD
194, 230, 250, and 292 engines use the same sheet metal. 235 and 261 is a different design. The 216 and early 235 valve cover can be used on late 235 and 261 engines by swapping a couple of rocker arm shaft bolts for studs.
Thanks for the info Jerry. So you believe the 292 and the 250 should be interchangeable?
'25 Chevy Superior
'66 Chevy C10
Not only the valve covers, but the entire cylinder head will swap, IMHO.
