3 members (klhansen, carbking, 1 invisible),
286
Mod | | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 71 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 71 | Are the 235, 250, 292 valve covers interchangeable? Can I put a 235 or 292 valve cover on my 250?
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior '66 Chevy C10 '03 Chevy Silverado 1500 HD
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | 194, 230, 250, and 292 engines use the same sheet metal. 235 and 261 is a different design. The 216 and early 235 valve cover can be used on late 235 and 261 engines by swapping a couple of rocker arm shaft bolts for studs. Jerry
| | | | | Joined: Jan 2020 Posts: 71 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 71 | 194, 230, 250, and 292 engines use the same sheet metal. 235 and 261 is a different design. The 216 and early 235 valve cover can be used on late 235 and 261 engines by swapping a couple of rocker arm shaft bolts for studs. Jerry Thanks for the info Jerry. So you believe the 292 and the 250 should be interchangeable?
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Not only the valve covers, but the entire cylinder head will swap, IMHO. Jerry
