2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#1515631 09/02/2023 11:11 PM
Moderated
Moderated
I've seen diagrams and aftermarket parts (like the Brothers/Holley part # TSA5600 turn signal assembly with cup) that suggests there was a factory option for turn signals on the column for '54.
It's time to replace the old Signal Stat on my '54 3100, so I'm considering options.
It would be nice to have an integrated turn signal assembly instead of the clamp-on. Has anyone tried installing one of these?
Crusty54,
1st off, Welcome to Stovebolt! wave
According to a couple different Chevrolet Master Parts Catalogs (1954 and 1957), the "turn signal assembly with cup" was offered as a standard part under Parts Group 2.895. The 1954 book indicated GM# 897334 (applied to 1954), but the later 1957 book indicated GM# 897125 (applied to 1954-55 1st Series).
You might want to check this old thread concerning the turn signal assembly that is a bolt on for your truck.
I recall a more recent conversation not long ago about this, but couldn't locate that particular thread. Perhaps another Bolter can point you in the right direction???
Anyhow, the above linked thread does provide additional info on things you will need beyond the noted switch assembly to install the unit your mentioned.
Dan
~ Dan
1951 Chevy 3 window 3100
The 897125 number Dan lists above is also valid for 55.2 and 56 GMC trucks with class B turn signals (ie. 6 wire switch). In '57 Chevy and GMC went to a dished steering wheel and the turn signal lever followed the dish, so the part that the lever screwed into was modified to include the angle of the dish.
Have not used a mechanical t/s switch for years. The electronic one is impossible to forget and has added features. We use the Kawasaki motorcycle switch which one can get from a m-c junkyard for ten bucks or one can buy an engineered one from Amazon for $60. One on my 37 Buick has been trouble free for thirty years. Just google "self cancelling electronic t-s switch."
Evan
