8 members (Otto Skorzeny, DavidBraley, Paul Mullen, Gray_Ghost, Gdads51, Hotrod Lincoln, Ponchogl, 1 invisible), 97 guests, and 6 robots.
Topics128,185
Posts1,057,200
Members48,465
Dont make fun of me too hard......
Ive looked thru 6 catalogs and my assembly manual. Cant find what this part is called? 🙃
"Commonly quoted life advice I dont even try to live by." -Famous Person
Steering arm
1949 gmc 1-ton
Ok, second question.
Does anyone know if 18" wheels will clear the stock steering arm, on a 1951 3100?
O Online: Content
It depends more on the width of the rims, the offset, and the backspace rather than the diameter.
Stock 16" rims with 215x85 tires on them are 30" in diameter. 18" wheels with tires that approximate that diameter or less will surely clear.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Aren't 18" wheels used on 1 ton (3800 series) vehicles? My 1959 1 ton flatbed ran those wheels. They had the same 8 lug bolt pattern as a 3/4 ton, but the 3800 had dual rear wheels.
Insomniac
Insomniac
I believe the OP is working on a 3100.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sorry i shoulda been more specific. Yes its a 3100. The wheels are 8in wide with 4.25" backspace. They will easily reach inward beyond the steering arm. Just curious if they will hit it or clear it.
O Online: Content
I don't know for sure but that seems excessive. 15"x8" rims were on my truck when I got it. I have no idea what the backspace was but it seems like they rubbed somewhere in there during lock to lock turns.
They were also too wide to steer easily with stock components and no power steering.
My current rims are 16"x6" with 3.5" backspace. They don't rub or anything but if I were ordering them again, I'd order 5" width.
327amc,
How about providing pictures of the wheels in question???
It almost sounds like your are describing later 6-lug "Rallye" style or standard style truck wheels that have the 8" width you mentioned.
Check out this older conversation on using wider wheels as it has a whole bunch of good info that may answer your question.
Dan
~ Dan
1951 Chevy 3 window 3100
Originally Posted by Gdads51
327amc,
Dan
It is these. Chip Foose Legend 18x8 and 18x9
If you are using these "5-lug" wheels, guessing you are converting your current hubs/axles to a matching lug pattern (or replacing with something other than stock)???
Converting your front hubs/rear axle will change a number of things with your truck as far as clearances go. Not just with the existing steering components, but also with fenders, truck bed, and possibly the frame/suspension (both front and rear).
No easy answer of yes or no without really knowing your entire plan. I would hazard to say that using the stock axles (even if you modify the lug pattern), best guess is they will not fit without a lot of other changes.
Dan
~ Dan
