6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
#1514055 08/22/2023 7:52 PM
Put in a new speedometer cable and its not working. I have a new speedometer in the dash so I’m guessing it is a problem on the trans side. I’m working on getting the trans out now and wanted to ask what’s involved in taking the speedometer fitting out of the trans and replacing it with a new one after I get the trans on the bench.
Doug
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
The speedo adapter on the trans just screws out. Assuming you're talking about a 3-speed tranny, the speedo gear in the tranny slips on the shaft, followed by a sleeve and then the u-joint yoke, held on by a bolt that prevents the gear from slipping on the shaft.
I have my doubts that the problem is in the tranny. You can check to see if the adapter is working once the driveshaft u-joint is disconnected from the torque tube. Put the tranny in neutral and turn the u-joint and watch for motion at the speedo adapter.
You can also check the speedometer with a variable speed drill connected to the cable...don't go wide open with the drill until you confirm it's turning in the right direction. You could have a bad speedometer right out of the box, I went through 3 that never made it to 1000 miles.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderator, Electrical Bay
Doug if you kept your old speedometer and if the new one isn't working (which won't be that uncommon) let me know. I've repaired several of them...not the new ones. The old ones are worth repairing but the new ones...not so much.
Good luck!
~ Jon
