7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP), 111 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
#1514052 08/22/2023 7:48 PM
I have these four fender braces, two of them cleaned up real good, two of them are broken on one end. The eyes on one set have a pretty good off-set, the others are pretty much in line. I need help identifying which are the front braces and which are the rear braces. Thanks
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
I believe that the one on the left (the pretty one with the offset end at the top) goes at the rear of the front fenders. I think there's a left and a right (I've seen markings on some of mine.) The top end bolts to one of the fender to cowl bolts.
The rear fender braces are straighter, as they bolt to the bottom of the fender and the bottom of the frame, both horizontal surfaces.
Thanks for the info. The catalog pictures of those braces looked the same front and rear.
1952 GMC
1967 GTO
1967 Firebird
Moderated by  klhansen, Rusty Rod
