Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
9 members (frogfarmer, 66flea, DoubleB, moparguy, ShopRag, Bill Hanlon, Wheelie, Dakota Bob, 1955 1 Series), 189 guests, and 1 robot.
Topics128,292
Posts1,058,590
Members48,492
Lew
Offline
I have a 51 3604 that needs new rims and tires. Is there a rim that matches the stock size while accepting the stock hub caps?
Are they 16 inch? Don't tell anyone, I used rims from a mid-eighties 3/4 ton ford on my 46. Tires are 235/85r16
1946 with WWII 270
24601
24601
Those actually look good. And they accepted the original hub caps ok?
Normally, for using F parts, I'd send the Brute Squad to give you a sound thumping. But as you are from *the* county, I'll let it go.
*This* time.
Not everyone can be from Kennebec County ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John those caps are 中國人 with no logo. I know I have the receipt somewhere if you need the supplier I bought them from.
1946 with WWII 270
Lew
Offline
Nobody with a 3/4 ton, besides msmall, has swapped out their rims?
Better to be lucky than good.
V
VEW Offline
V Offline
I have 17-1/2 wheels but have TF front and rear axle’s. So won’t help you.
~ Victor
1957 3100 - moved on
I wrote the following eons ago on this site.
I finally took a front wheel off my 3/4T and did some measurements with flat boards spanning the 16 in. one-piece rim. I come up with an inside bead width of 6 in. The inside mounting surface is setback 3 3/4 in. from the outside of the bead. These rims work with 235-85R16 tires (Michelin highway treads). One of the tire shops in town said they could order them so they should be available everywhere.
Stamped on wheel is:
16x6K (“K” is probably the bead profile.)
CAP 3045 LBS, 80 PSI, DOT T
5 12 21
Rockwell Fumagalli, Made in Brazil
I don't use hubcaps but can't you install clips on just about any wheel to hold them?
I'm using mid-nineties F*** E350 16" rims on my 49 3600. I don't have more specifics, I did that a few years ago but that's what the shop I got em from said they were taken off of.
I spaced the front rims out 1/4" although they did clear without; that was more of a caution as the rubber was close to the tie rod. No problems, have a few thousand miles (miles not KM) on it now.
I've got beauty rims on it and have been investigating dog dish hub caps using the clips ya rivet on. The bigger challenge I see is the rear - now on one of our fire trucks, we have a cool chrome center cap that goes over the full floater. I'd love to source something like that. I'll grab a picture next time I get a call out (just a voluntold).
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Fox Offline
Have you considered these rims? I bought a set for my 51 GMC one ton and they work/look great. I lost a little tire height from the original one ton running a 215/85/16 (iirc). Also, I haven’t gotten around to installing the cap clips yet.
Be sure to scroll down and check the reviews and feedback. It will help you. 😉
https://www.etrailer.com/Trailer-Tires-and-Wheels/Dexstar/AM20766.html
Here you can see that rim on the front of my one ton.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Crusty Old Sarge
Crusty Old Sarge
Check out Barnfind'49' he has F@&d wheel and factory caps.
https://www.stovebolt.com/ubbthread...-appearing-1949-gmc-150.html#Post1318581
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
What was the factory offset on a 1957 3600? Thanks
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore,
Below screenshot (taken from the 1957 Chevrolet Truck data document) shows there where 2 different sized wheels for 1957 3600. Offset depends on which wheel you have.
17.5" X 5.25" wheels had a 1/8" offset
19.5" x 5.25" wheels had a 7/16" offset
Dan
1957 3600 Wheel data
~ Dan
1951 Chevy 3 window 3100
B Online: Content
I don't know that Chevy had all the options that GMC did for '57 3/4 ton wheels, but below are the specs for all 3/4 ton GMCs from 55.2 through 59.
The first column is "Year Series". '57 is the letter T.
The second column is "Model". 15 is the regular 3/4 ton truck.
The third column is "Rear". EDIT My guess is that S is for Spicer (later Dana) 60. S = single rear tire, D = dual
The rest of the columns are self-explanatory.
There are a bunch of wheel options.
