6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
#1512565 08/10/2023 5:34 PM
What is the correct orientation of the coil on a 53? Wires up or wires down?
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
The original position was the high voltage nipple on the coil pointing down. Apparently, the idea was to prevent moisture, condensation, or rain splash from shorting out the high voltage spark. The coil will work the same if it's up, down, sideways, or backwards. It doesn't know, or care what position it's in, or where it's mounted, including on the tailgate!
Thanks Jerry.
1953 Chevy 3100
........including on the tailgate!
You'd have to buy wire by the reel!!
