0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 27 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 27 | Good Evening, I am getting my truck back from the body shop that painted it in the next two weeks and I am starting to build a plan to put the interior back together. Alot of the screws and bolts holding the truck together were mismatched, rusted, spray painted, sheared off, etc. For the re-assembly of the body I was able to easily find a SS bolt set to re-assemble the body panels, but I haven't been able to locate one for the interior. Does anyone know where one can be purchased or have a cheat sheet of the hardware required to re-assemble this?
Appreciate any information you guys can be provided. Super excited to be getting my truck closer back on the road. | | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | Classic Parts has the screws for the windshield and window trim. SS screw setThe only other place I can think of is the screws for the lower cab windless trim on the floor by the doors. Honestly, I just took a couple of the old screws to my local hardware store and matched them up to new Stainless screws.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Phak,
Like you, I went to Home Depot or Lowe’s for my interior screws.
Chris | | | | | Joined: Oct 2021 Posts: 6,791 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,791 | Ace Hardware is the best place to find oddball stuff in SS, regular, brass, etc. They have the old fashioned style , pull out drawers with every kind of screw and fastener you're likely to need. I've gotten many interior trim screws for various vehicles from them.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Agree with Otto. My local ACE has a great selection of "oddball stuff" screws, etc. My go to store for various fasteners,etc.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2023 Posts: 27 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 27 | Thanks guys, I guess at end of day there really aren't that many items, was really looking for things like the odd little screws for the glove box hinges, the vent cowl, etc. Easy enough to go through book and get right sizes. | | | | | Joined: May 2023 Posts: 443 'Bolter | | 'Bolter Joined: May 2023 Posts: 443 | Otto has it right. Ace is where I’ve found the best selection of SS screws and bolts. They also have a good selection of compression fitting.
Doug 1954 Chevy 3100One problem solved doesn’t seem to shorten the list Montgomery, ALIn Project Journals | | |
