2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1511358 07/31/2023 4:31 PM
I am still desperately trying to diagnose my driveline vibration. New differential and axle bearings. New u-joints. Driveshaft in phase. With clutch engaged it runs smooth for the most part. As I get to higher speeds I can feel a little vibration. About 50 MPH. As soon as I push the clutch in and disengage it I get a vibration. The more I slow down the worse it gets. It finally stops when I am under 10 MPH. If I reengage the clutch it stops.
I am a rookie when it comes to clutch and transmission so try not to laugh. Could the clutch be out of balance? When it is engaged it is stabilized but when disengaged it is free to wobble? I am just throwing stuff at the wall to see what sticks.
Dave from Northern Kentucky
My 54 3100
dgrinnan #1511395 07/31/2023 8:40 PM
Do you have access to a lift?
If so, do some precise measuring of the frame from side to side, diagonals front to back, etc. Study all four tires closely. Any unusual wear patterns from side to side? Rear axle might be cockeyed, etc etc.
If you don't have a helper, use a mason's line, mark the points on it with a Sharpie and measure the string when you're finished.
1950 Chevrolet 3100 (Ol' Roy)
