| | | Forums66 Topics128,258 Posts1,058,332 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 15 | Block number is a 41 per the decoder; 216 Can't read the gearbox number quite yet. Head cover looks like a 216 as well. About to see if I can get this to break loose with ATF-Acetone but as I read more I see that the rods are Babbitt and "aimed" oilers. So question - assuming this needs a full Monty rebuild - is it impossible for DIY? I'm used to MG and DeSoto engines with standard bearing shells. I read someone used to use jigs to ensure oilers remained aimed properly. Oh and some scary words along the way about thrust settings. I have started to look at 235 options as well but I'd love to ring what I brung if it's not a dead artisan only engine. Also any educational resources for this 216 task? | | |
