4 members (HandyAndy, David Bush, joe apple, 3B), 70 guests, and 1 robot.
Topics128,050
Posts1,055,753
Jim C. Blue
Jim C. Blue
I was out helping someone, and they had this old '76 Chevy C60 bus. Curious, I had a look inside and was reminded about old truck 5 speeds. However, the first gear was marked "L". I've heard of trucks all the way back to the 40's having 5 speeds, but have any of you ever experienced them? Like that bus, is it more of a regular 4 speed with extra low 1st?
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
I believe the shift pattern on some of the older Clark transmissions used "L" to indicate granny gear. It's possible that the 1-4 gears are all synchronized, with L and R being a straight cut spur gear that serves as both ratios, with an idler for reverse. That's how the SM-420 does it. 2nd. gear in a 420 can be selected without coming to a full stop, which gives a driver more options than the 3 speed does.
