2 members (Nick in Manitou, Hanks custodian), 93 guests, and 2 robots.
Topics128,035
Posts1,055,559
Page 2 of 2 1 2
There are two standard heights of radiator fill necks that will cover probably 90% of every American made vehicle for about 50 years. Is there any reason someone can't use a tape measure or a ruler, measure the inside depth of the neck, go to the FLAPS, and do some measuring of the caps they have in stock? "This ain't rocket surgery!"- - - - -or maybe I'm having a Mr. Spock moment- - - -"That is not logical!" Getting OCD about specific part numbers doesn't make the cut in the real world of auto repair.
In the interest of saving time and frustration at this parts store counter, I try to do their thinking for them before I even walk in the door. There is exactly one parts store in my town that’s capable of doing the simple task of measuring and referencing and they keep the shortest hours of any. Measuring caps in stock at this O’Reilly is a fine idea, but strangely they don’t keep 4 lb caps in stock.
I wrongly assumed that a 4 lb cap was a 4 lb cap without even thinking about fill neck depth.
I’m not the least bit picky about part brand or even part number. Was just hoping to find something (from someone here) that is already known to work so I can walk in, make my exchange, and walk out. I’m being lazy, basically.
1951 3100
Jerry’s comment about two different cap heights covering nearly all domestic vehicles is helpful context.
If that’s the case, it would seem that the taller of the two variants has quite a range of actual listed heights: 1-1/16” to 1-1/2.” The cap I bought is allegedly 1-1/16.” I’m not sure how how/where they measure from as that number doesn’t correlate very well with anything when I put a ruler on it.
The short variety is more consistently listed at 3/4.” I’ll try one of those.
1951 3100
Avoid a cheap cap that will expel fluid all over your engine.
Air valve may not leak but most I`ve seen do. Thats the dimple on top.
Get one if you want. I am trying to save people frustration.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Picked up a few things new 7 lbs cap new thermostat 180 degrees
Last edited by Gdads51; 07/27/2023 3:03 AM. Reason: fix text to allow pictures to display
This is no longer fun
Is my overflow canister to low ??
Mine is lower than that (and on the firewall) and it works fine.
H Online: Content
The height looks OK- - - -the capacity is a bit on the skimpy side. I like an overflow tank with a couple of quarts capacity- - - -with about a pint in it cold to be sure the siphon tube stays submerged. If the original cooling system was a "zero pressure" type, 7 pounds might put a bit of stress on the solder joints at the radiator tanks and the heater core connections. 7 pounds will allow the coolant to stay liquid up to 233 degrees at sea level- - - -much hotter than most stovebolters like to run their engines. Each pound of pressure raises the boiling point by 3 degrees. That's why food cooks faster in a pressure cooker- - - -the internal temp in a 15# pressure pot gets to 250+ degrees.
HRL Do you suggest a 4lb cap?? And not chance blowing the top tank out with a 7lb cap?!
I have a 4 lb cap on my truck with a recovery/return reservoir, 1941 radiator, and a heater. There are no problems with any of the components.
Engine is original, un-rebuilt 216. It, too has a 180 degree T-stat.
1950 Chevrolet 3100 (Ol' Roy)
Page 2 of 2 1 2
