4 members (68ironhead, Hanks custodian, Gray_Ghost, Ponchogl), 51 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#1510447 07/25/2023 2:45 AM
I have a 49 3100 with a 55 235 engine. Temperature gauge has been working fine for several years until a week ago when it stopped reading anything. I put a new thermostat in and temperature gauge still does not move. I think my next step will be to replace the sending unit. Anyone able to give me any other ideas what it could be. Thanks for any help.
dougs #1510453 07/25/2023 3:21 AM
Moderator, Electrical Bay
Do you have the mechanical type gauge or the electric type gauge? If it is the electric gauge and it stopped reading suddenly one of three things happened I think: 1---the gauge stopped working, 2---the sender unit stopped working (most likely, I'd bet) or 3---you've suffered a bad electrical connection or bad wire somewhere. To test your sender get a handheld meter and set it for resistance...maybe something like 0-200k ohms. Remove the wire at the top of the sending unit. Connect one probe from the tester to the top of the sending unit and the other to a good ground. Turn on the ignition with the engine cold and make a note of the resistance (may be something like 74K ohms or so). Then warm up the engine and take that same reading again. It should be much lower. Please let us know what that reading is and we can start chasing the demons.
~ Jon
Jon G #1510464 07/25/2023 10:28 AM
I'm not sure what you mean by "mechanical or electric". There is one wire (bare) from the sender to the temperature gauge. And the gauge just stopped reading. I warmed up the engine and the gauge does not move. So i'm thinking it is the sending unit.
dougs #1510465 07/25/2023 11:20 AM
Easiest and cheapest to replace sending unit. Maybe the wire at the sending unit is bad.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
dougs #1510474 07/25/2023 12:25 PM
If the "wire" is "bare" it probably isn't a wire.
Does the "sender" have a threaded stud and a nut or a slip on connector for the wire as shown in Guitplayer's picture below holding the wire on? If so, it is electric and the wire should not be bare.
If not, the gauge is mechanical and the wire is actually a tube containing a gas that increases in pressure as the engine gets hotter, moving the needle in the gauge. It the tube had been broken the gas escapes and the needle sits on cold forever.
dougs #1510497 07/25/2023 3:54 PM
This sender I have had good luck with.
Put a wire connector on if the wire is bare and try it. $10
ACDelco GM Original Equipment 213-4792
~ BD.
dougs #1510726 07/27/2023 1:42 AM
That "bare" wire isn't a wire- - - -it's a copper capillary tube attached to a bulb that's bolted into the cylinder head. The bulb and the tube are filled with a volatile liquid- - - -usually ether. Eventually, the tube gets damaged or springs a leak, and the needle stops moving. That type of gauge is almost impossible for a backyard tinkerer to fix. I have had some success buying a cheap mechanical gauge and swapping the liquid-filled bulb to an original stovebolt gauge head, but it requires an extremely cold liquid to condense the pressure medium like dry ice and alcohol, or maybe liquid nitrogen.
dougs #1510836 07/28/2023 12:09 AM
The gauge is mechanical and must have a leak.
So I will have to replace the whole thing tubing and gauge.
So my question is where can I get the whole unit, bulb, tube and gauge
Doug
dougs #1510838 07/28/2023 12:22 AM
Brian
1955.2 3100 Truck
dougs #1510843 07/28/2023 1:15 AM
If you like AC Delco , NOS is available on Epay..
Not sure where the classic part is made.
I would only like to do that change ONE time.
I put ALL AC N.O.S. in my cluster.
Todd
1950 Chevy 3100
dougs #1510845 07/28/2023 1:29 AM
Yes, that's why I asked if you had a mechanical gauge. If you happen to live where there's a gauge repair service, they can repair it. I had mine repaired 40+ years ago and it is still fine. Think the guy charged me $15 or something like that. He just installed a tube and filled it with either ether or pure alcohol. I can't recall which he used. Good luck!
~ Jon
dougs #1510878 07/28/2023 11:56 AM
If you go with classicparts.com you get a 5% discount using the promo code "stovebolt". Off sets tax. I have used there gauge. I am happy with it.
Dave from Northern Kentucky
My 54 3100
