3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I rent some shop space in a metal building. Inside the building I get absolutely no coverage. No internet, telephone or anything. I can get one radio station. About 15 feet outside the building everything wrks fine. Is there some form of antenna that will make a connection inside my shop?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Yes actually. They make repeaters and Cell phone repeaters that can be setup with external antenna. Some are made for your situation and reasonable cost other are business and handle lots of setup.
Radio just needs external antennal.
Do a google search for cell phone repeater for metal building
you will get all kinds of options.
weBoost and WilsonPro and HiBoost are used by of lot of way outside the zone people
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | We use several Panasonic wireless phones inside our house, all connected to a land line. There is NO cell service in the area due to our property being out of "line of sight" to all the cell towers in the neighborhood. I use a repeater near the back door to transmit to the phone I use in the metal shop 100 feet from the house. Jerry
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks Guys,
I use a repeater on my TV set up inside. I have all the boxes inside and out of sightA few years ago I learned what a repeater was, I think we called it a re-trans on the Army radios again due to line of sight and distance issues. They also said use a barb wire fence for an antenna.
I will jump into the repeater business and see what trouble I can get into.
Thanks again
