| | | Forums66 Topics128,214 Posts1,057,484 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | I applied urethane primer on my front fenders today. Everything looked fine until I came back in to turn off the fan and lights. Then, I noticed a blister about the size of a quarter raised up in the middle of one of the fenders. I'm hoping that somebody can tell me what may have caused it. The fenders were sand blasted to bare metal, then Kirker's epoxy was applied. Some dents were hammered out and filled. Lots of sanding was of course done. Then today I applied the urethane primer. It all looks fine except for the one big blister. I'm sure that I did something wrong, but I have no idea what.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: Jul 2023 Posts: 58 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 58 | Is it on a horizontal surface, or vertical surface?
Either way, pop it, wait till full cure, take a blow gun, and try to blow right inside the popped bubble and see if more paint will come off. Really pick at it. If it sticks, its good.
If it blows strips off, obviously theres a contamination issue.
"Commonly quoted life advice I dont even try to live by." -Famous Person
| | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | It was on a horizontal surface, although the fenders are not on the truck, so I can position them however I need to. Thanks, I'll do as you instructed. and THANKS
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Pre-spray prep? Did you do a final wipe with a degreaser, using latex gloves so the oils in your hands wouldn't contaminate things? Did you let a drop of sweat hit your fender before applying paint? | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Agree with the above. Sounds like not keeping things like a hospital surgery room. No bare hands allowed on surfaces you want to paint. Don't learn to paint watching shows like overhauling, with bare hands all over everything they are going to paint. Latex gloves may not be a good idea they dissolve in the thinners and solvents.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | You guys are right on. I wiped the fenders down with prep sol when I started the whole process. But I did use bare hands and did not wipe them down prior to primer. I assumed that it would be OK after all of the sanding & etc. That's what happens when amateurs get involved. I'm pretty old to be learning, but I'm learning (the hard way) just the same. Thanks for the help.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Sorry, should've said powder free nitrile gloves. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Back in the late 1990's I was teaching collision repair in a big high school in Nashville Tennessee. Lots of my students lived in the inner city housing projects. We started getting an epidemic of "fish eye" blemishes in several of the jobs we were doing- - - -both spot repairs and all-over paint jobs. I was using all the routine precautions popular at the time to avoid contamination of the surfaces prior to painting, yet the problems persisted. Wearing Nitrile gloves hadn't yet come into general use at that time. Quite by accident, I discovered the source of the problem. Some of my students of a particular ethnic group were using Vaseline Intensive Care lotion as "ash killer"- - - -slathering the stuff liberally onto their skin to give it a shine instead of the gray appearance caused by dead skin cells sloughing off. Sand some Bondo or primer,- - - -rub a palm over the surface to check for roughness- - - -any guess where the body lotion ends up? I solved the problem by explaining- - - -very delicately to avoid accusations of "racism"- - - -what was happening, and having the kids scrub down with soap and water like a surgeon prepping for the operating room before going into the shop! Jerry
| | | | | Joined: Jul 2018 Posts: 282 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 282 | Sounds like the lotion would cause that, alright. But, also, any lubricant with silicone, in the shop could contaminate inadvertently. I’m always afraid to have that stuff around.
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | The urethane primer is likely less expensive compared to what yet remains to be sprayed. Do you err on the side of caution and strip the fenders completely as added insurance that a repeat bubble performance doesn't occur after all the expensive paint goes on? Food for thought... | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Had that happen to me due to a drop of sweat while I was priming recently. ticked me off something fierce. I sanded well and had some 2k rattle can I went over a bunch of times to build it back up. | | |
