1 members (moparguy), 313 guests, and 3 robots.
Topics128,164
Posts1,057,081
Members48,463
Page 2 of 2 1 2
Im assuming this is the jet in question. It says 51.
The tube on my 'power piston' appears slightly bent.
"Commonly quoted life advice I dont even try to live by." -Famous Person
Also the t.b. does measure 1.5" dia.
Moderator, Electrical Bay
That's a 235 carburetor, but if that is really a 51 size jet it is no wonder at all why you need your choke on to keep the engine running and why it sputters and stops without the choke halfway engaged. That is a small jet and will cause the carburetor to run pretty lean to very lean. 58 size was a common jet back when we had real gas. 59 or so might be better with ethanol. Your power piston does appear bent...straighten it, please or it may stick and hang up in your power valve opening. Which would interestingly cause you to run too rich or...if the bent piston was causing the power valve never to engage, you would be running way too lean when you needed power.
However, the 58, 59 jets were for the 235 and not for the 261 (but you don't have the right carburetor for the 261 so just changing to a much larger jet might or might not help you).
~ Jon
Looks like problems pretty well solved. I drilled out the .051" jet to .063" and (after tuning) she will idle perfectly with choke disengaged. However, she will idle up with choke out to near 1/2 engaged, but then she falls off after that. So i'd say .067 may be the ideal jet size. But im happy with how she is for now. I wont bother with. I'll try and run rec. gas and see how she responds.
Thanks for all the input. That solved the issue. smile
Once you get tired of tinkering with a Rochester, put a Carter YF for an AMC/Jeep 258 cubic inch inline six on it. Those carbs are 30-something years newer, much better quality, and are factory calibrated for an engine almost exactly the right displacement.
Riding in the Passing Lane
The power piston must push up & the spring pushes it down to knock the ball off the seat. Turn it around to make sure it will work in all positions. You may have to bend it to go into the center of the hole.
Don't go larger than the .063 jet size. If you have to do that to get it to run right, something else is wrong. If a little is good it doesn't mean a lot is better.
The choke is made for cold start & run. It is not for regular driving.
George
1972 Chevy c10 Cheyenne Super
Moderated
Moderated
Possibly a lean condition created by vacuum leak(s).I use carb spray while running and make short shots at critical areas, those related to manifold vacuum.
Anything between the base of the carb and head.
The idle rpm will change if you hit a leak, usually stumbles a little.
You'd be surprised how many you may find with a hand-held tach that you may not notice by ear.
Keep spray from carb throat and just small, short sprays.
2 cents
RD
Page 2 of 2 1 2
