3 members (Hotrod Lincoln , 2-Ton , 1 invisible),
63
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,021
Posts1,055,353
Members48,420
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Crusing in the Passing Lane
I lowered the radiator in my ‘55 to better align with the Cummins fan. Ed
Did you also move it forward? What are you doing for a shroud?
Did not move it fwd, started project by mounting I’cooler in front of radiator, fits without moving radiator, then moved engine back to clear radiator before building doghouse. Will build shroud to fit fan after have it running. Ed
Looks like it should work real good.
