1 members (Steelonsteel),
94
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Is there a source for a socket that fits the cover on the brake master cylinder on a 1950 GMC 453 truck? It’s a square nut on top. Haven’t measured size yet. Started to get back to work on my Old Firetrucks and need to check fluid level. It’s on tight. Thanks | | | | | Joined: May 2015 Posts: 11,086 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,086 | If you've got a welder it wouldn't be hard to make a wrench to fit the square nut. It would just take a couple lugs welded to a flat bar and a socket welded in the center. I made a tool like that for the steering gear bearing adjusting plug jam nut, which was way bigger than any of my sockets.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Thats probably what I’ll end up doing..hit the pawn shop for a big socket to weld to. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Measure the square and then do a search for an eight point socket that size. Eight point sockets are for square nuts and bolts.
Evan
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | eagleuh1 Here in the corn belt have learned to make square drive sockets out of wore-out disc bearing inner races,they are hard anneal them weld on whatever is needed to drive it. Or torch out a square drive piece of plate weld on a driver. By chance found a tee handle driver that fits the hex ones,hard to hurt it thru that floor board hole !! Also might use 3/4 or 1 inch drive socket turned the other way to shake it loose, | | | | | Joined: Jan 2022 Posts: 30 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 30 | a 3/4 wrench fits the nut I have 1 with the box end opened and put that on the nut with another wrench thru the box end like a t works every time | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | hippydave I've done that it works,worst thing is a plastic one. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | I found the right tool, unfortunately it rounded off the cap square without loosening it. My master is leaking apparently at the fittings , so I’ll probably just replace if I can find one. I can’t see a number on the in place master, just Wagner Lockheed on inner side. Can’t see outboard side of master. Would anyone know of a source for the master cylinder for a 3 ton 1950 GMC 453 truck. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy eagleuh1, according to my brake parts catalogue the master cylinder for your truck has a 1.5" bore, the Raybestos p/n for that master cylinder is MC13066. I checked RockAuto for that p/n, no parts found. Good luck with your search. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | There are companies that can sleeve your existing MC and rebuild it to new, like White Post Restorations in Virginia. Mike B  | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | That plug is most likely die cast ("pot metal") Use a hammer and punch to break it up, clean out the pieces, and replace it with a rubber expansion freeze plug with a tiny vent hole drilled through the center bolt. Problem solved! Jerry
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Thanks, probably what I’ll do this weekend. Still looking for a replacement Master or rebuild kit. Gonna try and get mirror in to look for number on frame side . Don’t want to take off if can’t get kit for it. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | We usually rebuilt master cylinders "in place" by removing one or both end caps and replacing the pistons and seals. If the area of the cylinder where the piston travels isn't rust pitted, there's really no reason to remove it from the frame. I've even honed a few of them "in place", although cleanup of the abrasive residue from the hone can be a challenge. Jerry
| | | | | Joined: Sep 2009 Posts: 5,953 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,953 | eagleuh1, Just a note that while searching for other parts/things, came across this eBay ad for a correct 1-1/2" diameter bore master cylinder rebuild kit in case the cylinder you have is still rebuildable. Let us know about the casting number if you can read it and good luck on getting the brakes fixed up.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Jim Carter says they have it, but says the bore is 1 1/4" ... https://oldchevytrucks.com/me166.html A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
