| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15096 01/28/2002 11:39 PM | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | When I swapped my parts over from my crunched 53 to the newly aquirred 50 -3100 series, I did not change the gas tank sending unit. The sending unit in the 50 has never worked (maybe electrical?). Nevertheless I noticed that the unit in the 50 is like a worm gear type with the ballast being connected to one gear (in a vertical position) meshing another gear which is in a horizontal position that is connected to the long shaft up to the top.
The unit that came out of the 53 has its ballast connect to a different type of pivoting mechanism but also has a copper like ribbon which runs parrallel with the long shaft up and down.
Can I use the 53 sending unit in a 50 truck ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#15097 01/29/2002 2:26 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I want to go ahead and just say "Yeah the 53 and 50 senders have the same Ohm readings", but it's best to just test each one. Take an Ohm meter and connect the negative lead to the sender housing and the Positive lead to the center terminal and move the float arm through it's travel range and record the reading. Test both and if their both good you have a similar reading. You could also find a bad sender by testing the senders in this manner. What I also do is connnect the hot wire to the sender terminal and take a jumper ground wire and connect one end to the sender housing and the other to the truck metal. Turn the key on and move the float arm through it's range and you should see the gas gauge needle moving.
Joe
#15098 01/31/2002 3:49 AM | Joined: Aug 2000 Posts: 14 Member | | Member Joined: Aug 2000 Posts: 14 | Personally, I prefer the ones with the gears. The electrical portion sits high and dry instead of dangling in the tank corroding. Just my two cents.
Barrett Revis '53 3105 '48 3105 The fewer the moving parts, the less there is to go wrong... | | |
