| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Did a 1942 235 still have babbit bearings and a splash oil system?
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | 235 didn't have insert bearings and full pressure oiling until the 1953 Corvette. Someone will correct me if I am mistaken.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | The 235 was introduced in 1941 with the same Babbit-lined rods as the 216. The first insert bearing 235 was a 1954. That being said, there was a conversion bearing available for bored-out spray-oiler rods by the mid-1950's, so it's possible to find a spray-oiler engine with removable rod bearings. The Federal-Mogul part number for those bearings is a 1415SB. The rods MUST have the Babbit lining machined out and honed to the proper diameter to use those bearings. Jerry
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Thanks for the info folks.
Rick
