1 members (J Lucas),
94
0
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 338 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 338 | I just remembered my old Stovebolt (1955 1st) used to need lead substitute added to the fuel. How would I know if my current trucks will need it?
1954 Chevy custom 261CID, T-5 5 Speed. 1952 Chevy 6400 2 ton hydraulic flat bed.
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | I wouldn’t worry about it. Just fill er up and go. 1949 gmc 1-ton | | | | | Joined: Oct 2021 Posts: 6,734 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,734 | No vehicles need lead or needed it in the past. Your '55 didn't need it either. You were just lead to believe it did by the popular myths that sprang up when the Feds outlawed it in '74.
Everyone used to say the exhaust valves would burn without lead in the fuel to lubricate them.
Well, leaded fuel hasn't been around for use in automobiles for 50 years and I've never seen or heard of a case where that actually happened.
Hi revving, high performance race engines going flat out all the time might experience premature exhaust valve wear without lead but no normal car will.
I've been driving all my vehicles without additives forever with no ill effects.
As I mentioned in another thread, unleaded fuel has been used in automobiles for 100 years. AMOCO invented it in 1923 and it didn't hurt vehicles then and it it won't hurt them now.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jun 2016 Posts: 338 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 338 | I appreciate the info. What a relief.
