0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#150827 02/07/2007 4:53 PM
Junior Member
Junior Member
I thought I had a 235 six cylinder in my 1955 2nd seies 6400 truck but while reading the old post on the forum I came across some literature that said there were some 261 engines in the bigger trucks and it listed the block number for the 1955, 261 as 3837012. When I check, that is the number on my block. Also it looks like under the orange paint on the engine it used to ne painted yellow.
[img]http://thumb9.webshots.net/t/59/759/7/48/39/2864748390100433169qHIIMn_th.jpg[/img]
#150828 02/07/2007 5:15 PM
check for captains bars at starter,,,261,,,,doc
#150829 02/07/2007 5:54 PM
V
V Offline
Congratulations! You have a 55-57 261 motor! Look for yourself at: http://www.inliners.org/casting/numbers.html
#150830 02/07/2007 6:22 PM
Junior Member
Junior Member
I am working on getting the brakes to work right now. Also have a fuel tank problem but the motor runs very well. A little more work and she'll be road worthy! Thanks for the help.
#150831 02/07/2007 7:17 PM
Not all 261's have the Captains Bars. That casting no., on the passenger side of the block, is the best indicator. I had a engine, I pulled sitting here, that I thought for the longest time, was a 235, but after the previous owner insisted that it was actually a 261, I looked it up on the inliners site, & discovered it was actually a 261. It had no Captains bars, as my other 261 had.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
