1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1507851 07/04/2023 8:31 PM
Hey y’all,
This may have been asked a million times, are the clearance and torque spec for the 235 the same across the years? I have one that I think came out of a 56-62 car(?) but have the spec sheet for 53’ and older. Cheers! chug
Csteve #1507861 07/04/2023 9:58 PM
H Online: Content
Not enough information- - - -which specifications are you talking about? Lower end clearance specifications like connecting rods, min bearings, etc. are the same. Rod and main bearing torque is the same. Cylinder head bolt torque might be a little different on some engines depending on the number of head bolts. Valve clearance can vary according to year and car/truck differences.
