| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2023 Posts: 7 'Bolter | | 'Bolter Joined: Apr 2023 Posts: 7 | Hey y’all, This may have been asked a million times, are the clearance and torque spec for the 235 the same across the years? I have one that I think came out of a 56-62 car(?) but have the spec sheet for 53’ and older. Cheers!  | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Not enough information- - - -which specifications are you talking about? Lower end clearance specifications like connecting rods, min bearings, etc. are the same. Rod and main bearing torque is the same. Cylinder head bolt torque might be a little different on some engines depending on the number of head bolts. Valve clearance can vary according to year and car/truck differences. Jerry
