0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
I am thinking of putting a power booster on my 1942 Chevy 1-1/2 ton panel truck. Any one have pictures or know where I can find information and a booster for it? Thanks!!! [email protected] 1-262-392-2989
Marv.
3B Offline
Hy Marvin, I'm pretty sure a 1 1/2 ton should have come with a hydravac from the factory. Are you keeping your system a stock single system? If you are keeping it stock, you should be able to find a new or rebuilt remote mount booster [ hydravac]. If you want to upgrade to a dual master cylinder, there are kits available I think, hope that helps
I plan to buy the generic booster/master cylinder assembly and mount it backwards under the cab where the factory pedal and linkage will operate it. Will require a custom built bracket of some sort to be sure. That's what I'm planning.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
I am keeping the brake system stock put would like the extra push a booster will give me. Thanks!!! for your replys for far.
Marv.
Marv, here is the under cab type hydro-vac unit at a decent price on Ebay.
http://cgi.ebay.com/ebaymotors/REMA...566QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
He has it listed as fitting your truck.
Hobert
"The Lord is my shepherd"
Marv,
I'm sure you know this already, but I believe the 41-46 big trucks only used the "Brake Booster", which is technically different than a Hydrovac. The Booster strictly uses vacuum to assist in the mechanical application of the existing Master cylinder. It's really just helping you push the pedal down.
The later trucks used an actual Hydrovac, as shown in the e-bay listing. These, to my way of thinking, are more complicated, as they include the slave cylinder, which actually does the work of pushing the brake fluid through the lines. It must be included in the bleed process. They are a bigger boost to braking effort than just the brake booster.
That being said, no reason I can think of you can't put an actual Hydrovac on the earlier trucks. I think a proper installation would include a check valve in the vacuum line, which is typically mounted on the fire wall, above the level of the carburator. The check valve, I believe, prevents "Chloro-Flourocarbons", or Dilithium Crystals, or Cholesterol, or some-such free radical, from filtering back to the Hydrovac, and eating away the rubber diaphram.
Either way, I'm told the most important thing, after bleeding the hyrovac, is to keep the air filter clean.
Good luck, and post about your results.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
