2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | I'm upgrading my Intake Manifold and carb on my small block 283. Does it matter if I'm fitting an aluminium Intake to cast cylinder heads? Cheers. | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | Stooby, Just my $.02 worth but I have been running an aluminum intake on a '66 327 since 1985. You shouldn't have any issues if mating surfaces are all good.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Stooby Where aluminum intakes suffer is when they set for months not being used. They will get bad corrosion like cavities in human teeth. A friend with a 454 3x2 intake had to have extensive heli-arc welding to save his. You can use Dex-Cool anti-freeze and service it to help. | | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | Be sure to check the torque on the manifold to head bolts frequently, and use hardened steel "SAE" flat washers between the bolt heads and the manifold. Anti seize compound on the bolt threads is also a good idea. The different expansion rates between the aluminum manifold and the steel bolts has a tendency to compress the gaskets and create vacuum leaks. Jerry
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | I have aluminum intakes on ALL of my carbureted engines and, knock on wood, have never had an issue. One went 360,000 miles after I bought the truck and installed the aluminum intake.
I did have the issue Jerry mentioned, but with an aluminum cylinder head (about 4 inches thick, rather than the 1/2~3/4 inch thickness of the intake mounting flange).
The different expansion rates not only compressed the gasket, but stretched the head bolts.
Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | I holed a piston on a 460 cubic inch Dodge 440 truck pull engine during a dyno run one night, because a couple of intake bolts loosened up and created a lean condition on one cylinder. Of course, that was at 6500 RPM and 700+ HP on one (Quadrajet) carburetor and gasoline!
