| | | Forums66 Topics128,049 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 64 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 64 | Hello,
I am making progress on my 1954 3100 S10 Conversion. I am using the stock hydramatic steering column with stock shift lever. I will swap out the stock indicator with a modern indicator. But I can’t figure out how to connect the column shifter to the tranny linkage.
Has anyone used the stock 54 shifter plate (bolts on top of the end of steering column, with shift rod running thru it) to connect the tranny linkage to the column shifter?
I’m beginning to understand why aftermarket columns with column shifter are used.
Thank you for your comments.
1954 3100 with Hydra-Matic Currently undergoing S10 conversion Parkinson’s...it’s not just for the elderly Caution, slow man at work
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You only need shifter arm on column to move four positions---park, reverse, neutral, and drive so why use an indicator? Picture is an AD on S10 chassis that includes a start in park only safety switch. The shift rod is just a piece of 3/8 rod turned down to 5/16 on the ends. [img]https://i.postimg.cc/QH31c8Hx/S10-055.jpg[/img]
Evan
| | | | | Joined: Nov 2012 Posts: 64 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 64 | Does your setup have a “gate” (lack of a better word) to prevent accidentally shifting into R?
| | | | | Joined: Jan 2022 Posts: 2,444 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,444 | The picture that Evan posted is of a 3 speed manual shift box. It wouldn't have a "detent" like your HydraMatic shifter had when it left the factory. Most of those wore out many years ago.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
