Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Ridgeback, baldeagle, 3B), 37 guests, and 0 robots.
Topics128,005
Posts1,055,253
Members48,418
Page 2 of 3 1 2 3
Originally Posted by Phak1
You and your son are progressing nicely. Your making memories that you both will cherish for a lifetime.
Thank you for the kind words, Phil. When my son was 16, we went to a wrecking yard and bought him a '65 VW bug for a father & son project. That turned out to be mostly him rebuilding and me spending (he taught himself to do it all). That was 11 years ago (the '65 bug is still in my garage, too). It's fun to have him help me with my project for a change!
I spent about half the day today on my project (had to watch the Super Bowl with the wife). I decided to tackle the rope main bearing seal on my 235 again. This time I had good luck on my side and had the crankshaft, timing cover rear plate and cam shaft installed. I'm a happy camper! I started cleaning up my pistons. The old "new" rings were glued in the grooves and I managed to break a few of them so I'll be replacing them all for good measure. When I got back home, I had a nice surprise waiting for me; my Novak SM 420 rebuild kit! This is going to be a good week!
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
2 Offline
This is a real fun project to follow! You and your son are doing some very nice work.
Steve
I recently got the bottom end of my 235 engine buttoned up so it was ready to get off the engine stand and set it into the frame. Before I could do that, I needed to get the new brake lines installed. Instead of buying a 25' roll of tubing (I would never need that much), I chose to go with pre-made sections (with fittings) from my local NAPA. I planned out the runs so that I'd have a minimum of cutting/flaring to do, and a minimum of fittings. I used 1/4" nickel coated copper tubing which was very easy to shape by hand (although I used a tubing bender for the tight turns). Both the front and rear circuits have 10 lb. residual valves installed right at the master cylinder. While I was able to complete the circuit to the front brakes, I did not finish the run to the rears. I still need to purchase an adjustable proportioning valve which will go in the line near the rear axle.
Once the brake lines were in place, and I had put my clutch and brake pedals back on, I was finally able to set the engine into the frame. This was a big milestone and I celebrated with a couple pints of Guiness afterwards.
Turning away from the engine project for a little bit, I decided to work on my front brake situation. To recap, I am converting my 3/4 ton truck from Huck to Bendix brakes on the front. I was able to acquire a pair of backing plates from another Stovebolter not too long ago, which got the project moving in the right direction. What I didn't know at the time, though, was that the '53-'59 3/4-ton brakes also have a separate sheet metal piece that slips over the spindles to close off the openings in the backing plates (spaces needed to allow the backing plates to clear the turn stops). Instead of searching for a pair of these covers, I decided to make them myself. They are made of 18 ga. sheet metal and 1/4 sections of EMT conduit. I used a plasma cutter to cut out the sheet metal bits, and then put it all together with my mig welder. When the cover was all welded together and dressed out, I temporarily bolted it to the backing plate, chucked it up in the lathe and bored the spindle hole. A little tweaking of the bolt holes later and the first one is ready to be painted.
Brian
'83 GMC Sierra 4x4
Righty Tighty, Lefty Loosey
Those look like they took a ton of work, but they turned out great.
Nice job!
Great post BTW.
Steve
1946 Chev 1/2 ton - 6V/+ground/Bias-ply original - shake/Rattle and Roll! (SOLD)
1940 Chev 1/2 ton Franken/Restomod
Yep, another post that shows just how just inadequate I really am in the shop!!! smile Good Work Sir. And I appreciate the warning to get that extra shield if I'm ever successful in gathering the parts to convert my Huck brakes to Bendix.
RonR
RonR
1970 340 Duster
1964 CJ5
Steve and RonR, thanks for the kind words! You know, they really weren't that much work once I could visualize the end result. I searched my area for a donor '53-'59 3/4 or 1-ton truck but came up empty. I searched the internet for photos, drawings, etc. but came up empty. All of the shop manuals seem to use the same grainy photos of 1/2 ton Bendix brakes, so they were no help. I finally found a complete set of Bendix brakes for sale on a website called "20-40parts.com" for just under $100 plus shipping from the midwest. I was tempted to go that route but I couldn't see any means of contacting the seller directly with questions, which is a red flag for me.
Brian
'83 GMC Sierra 4x4
Crusty Old Sarge
Crusty Old Sarge
That is great work on the backing plates, once it's complete it will look factory original. Next on my shopping list a Plasma Cutter.... "Oh Dear, I really need to buy this"
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
AD Addict & Tinkerer
I agree, nice work!
Phil
Project Journals
Stovebolt Gallery Forum
Sorry Brian, found these at the bottom of the barrel.
Your fabed ones are much prettier.
Amazing work.
RZ
Amazing work.
RZ
Lol! That's too funny. I thought about sending you a PM about them, but I figured I had already bothered you enough about it all. Everything turned out pretty good in the end.
Brian
'83 GMC Sierra 4x4
I'm getting very close to having the mechanical work all done. I think the only thing I have left to "rebuild" is the steering box. Since my last update, I've finished the rebuild of my SM 420 transmission and got it installed. I finished my front Huck-to-Bendix brake conversion, and I received a new set of alignment rings which allowed me to get the intake/exhaust installed on the motor. I then went back to my favorite wrecking yard and acquired the two-piece drive line out of a poor old '54 GMC 3/4 ton pickup. After it was all cleaned up, and with new universals and support bearing in place, I fitted it up between the transmission and differential so I could work out the angles.
With the frame level I first measured the angle at the carburetor base, which gave me 3.7 degrees (down). I then set the differential pinion angle at 3.7 degrees (up) so they cancel out. I then raised and lowered the drive line with a floor jack just ahead of the support bearing until both sections of the drive line were at the same angle (7.1 degrees), in other words the two sections are 'flat' relative to each other. Since the Dana 60 rear axle I'm using has an offset diff, the rear section of the drive line is angled, too. The (sideways) angles of the universals at the slip joint and at the diff are the same, so they also cancel out. The new support bearing I used is of the modern type that comes installed in a carrier, and it is not as 'tall' as the original set up. So with the drive line set in position, I took measurements to make an adapter spacer to go between the new bearing carrier and the plate that is riveted to the frame crossmember. With all of the fun stuff out of the way, I welded the spring perches on the rear axle, installed the rear shock mounts and shocks, welded on a bracket to hold the end of the flexible brake hose and "T" fitting, and then painted the rear axle.
I should point out that I did all of the above twice: with and without about 200 lbs. of dead weight on the rear end of the frame. The results of my measurements netted a difference of less than a degree, so I felt pretty good about the whole thing.
I've also started working on some of the sheet metal bits for the front end. Since I figured I'd better get the motor to a point where I can test run it pretty soon, I dug out my radiator and radiator support. A previous owner really tried to butcher the radiator support in an effort to do what, I'm not sure, but it had quite a few cuts and gouges in it from a grinder, and several areas that weren't flat anymore. Also, the bar that goes across the top wasn't attached to the support; both welds had been chiseled apart. So after a bunch of welding, grinding, hammering, etc. the support was one piece again, then cleaned and painted. I also cleaned, repaired and painted the sheet metal apron that sits at the bottom behind the grill, and the piece at the top of the radiator that holds the hood latch.
My son is pretty close to having the distributor complete (just got a whole bunch of parts from Bowtie Bits) and is also working on my carburetor. A few other items are on the way to get the motor ready for that first start up. On my immediate to-do list is get the last of the rear brake lines installed and the system bled, and install the parking brake cables.
Happy Easter everyone!
Brian
'83 GMC Sierra 4x4
Im not 100% sure but dont you need to have at least .5 deg of angle from any joint? Otherwise the cups or needles get wore bad in 1 spot or the grease dosent get pushed around in them. I remember setting mine up on my truck when I swapped it. Was a pain to measure 20 times then do all the math and adjust the crossmember to get the height jusssttttt so.
I know that you need to make sure that the universals are "loaded up" so that they stay in business. All three of the universals in my driveline are at some angle either horizontally (the 2nd and 3rd universals) or vertically (the 1st universal). None of them are in-line, and the net angle is zero (or as close as possible to it) to prevent vibration. Of course the only way I'll know for sure how it all feels is to drive the truck, but that's a ways off yet.
Brian
'83 GMC Sierra 4x4
Gotcha. I used the tremec app on my iphone and it helped make sense of the angles. You literally use the level in the phone to measure 3 angles and it gives you your totals. Pretty neat setup.
I used a free app called "iLevel" which works nicely, and the graphics (changeable) are easy to see even without my reading glasses on.
Brian
'83 GMC Sierra 4x4
Since my last update I've been busy with actual 'work' stuff, so progress on the truck has been slow. When I fitted up the drive shaft I discovered that the yoke at the tail end was not the same size as the yoke in the differential. I purchased the correct size 'weld tube yoke' from a local drive shaft supplier and have prepped the tube for the new, larger yoke. I also shortened the tube 3/4" so that the splined expansion joint between the two drive shaft sections wouldn't be bottomed out. I could weld the new yoke onto the tube, but I think I'll let the shop do it so they can re-balance it at the same time.
In the meantime, I finished installing the rear brake lines and with my son's help, have bled the entire brake system. I also installed new parking brake cables. That completes the brakes until I install the cab and can adjust the parking brake cables.
Going back to getting the motor ready to start, I put water in the block one day to let it set a couple days and check for leaks. About 5 minutes later, I saw water drooling down the side of the block from behind the exhaust manifold. I removed the manifold and found the water coming out from behind the brass rebuild tag affixed to the block. Whomever installed the data plate drilled through to the water jacket and the little brass rivets were not water tight! I wanted to keep the plate in place, so I drilled and tapped the holes for 8-32 screws and installed them with Permatex. After a couple days, I filled the block with water for another check and everything was dry. So the manifold went back on and I looked into a new exhaust system next.
After doing a fair amount of research, I chose an exhaust kit from Chev's of the 40's. They are located about 2-1/2 hours south of me, so I figured I'd save on shipping by picking it up in person. The owner has his own car museum at the showroom site, too, so visiting that was a bonus. Also, a few miles away is a wrecking yard called "All American Auto" that has a field full of pre-60's autos and trucks, so my son and I had to spend some time there as well (picked up a suitable air cleaner and a proper remote oil filter housing).
After getting the kit home and checking it against my truck, it became obvious very quickly that the header pipe was not correct for my truck. I have a 235 motor, but it has the older 216 style exhaust manifold that exits straight down. Ok, so I called the vendor and arranged to swap out the header pipe for the correct one. My son and I were headed to Oregon anyway, so a stop at the vendor's warehouse to make the swap was easy. When we got home and tried to fit the new header pipe, again it was not quite right. The new pipe is for a '41-'46 truck with a 216, so the vertical portion going up to the exhaust manifold wasn't really the right shape.
I went through my options and finally decided to just make what I had fit. So I cut the flared end off of the new header pipe and temporarily installed it into the exhaust manifold. Then I heated up the bend in the header pipe and straightened out the vertical portion to line up with the manifold. I then MIG welded the two pieces back together. With that done, I installed the muffler to the end of the header pipe and attached it to the frame with the proper clamp/strap. With that all hardened up, I then fitted the tail pipe which also required a small amount of heat at one bend to get it lined up properly, but it's done!
Now to get that carburetor rebuilt and I can find out what my engine sounds like!
Brian
'83 GMC Sierra 4x4
You got to wonder, what mechanic would think they could stop coolant leaking out of a hole drilled into the coolant jacket with a brass rivet. The cycle of heating and cooling on dissimilar alloys is going to eventually shrink that rivet to the point that it leaks.
Taping and installing screws was a great way to fix the issue. Nice fix!
Phil
Project Journals
I have to wonder how many other motors were tagged like that over the years, and how many complaints Perkins may have received from its customers! I tought about plugging the holes but really wanted to keep the Perkins rebuild tag in place as it is part of the history of the motor. Funny thing is you have to bend way over to see it under the manifold, so when the fenders are back on the truck, you probably won't be able to see it at all.
Brian
'83 GMC Sierra 4x4
Continuing towards getting my 235 ready to start up for the first time, I recently finished installing a new GM 12v alternator. I bought a replacement pulley for a 5/8" wide belt in order to match my crankshaft and water pump pulleys. I looked at the commercially available kits for mounting an alternator and decided to do something much simpler using the original generator bracket. I made a bolt long enough to pass all the way through the bracket, then made a temporary spacer out of a piece of 1/2" pipe to fit between the alternator and the rear end of the bracket. I then test fit it on the block to check the pulley alignment. As you can see in the first photo, it was too far to the rear (exactly 1" as it turned out). I drilled two new mounting holes in the bottom of the generator bracket which moved the mounting forward 1". After another test fitting to make sure the pulleys were lined up, I moved on to finding an upper bracket that fit. I had available a bracket from a Chevy 250 inline 6 and one from a Ford 300 inline 6. The Chevy bracket had a tighter curve to it which interfered with the alternator's fan. The Ford bracket had the right curve, but had an offset bend in it at the middle that put the slotted arm too far to the rear. I decided to use the Ford bracket and after some heating and beating to change the offset bend towards the front, it fit really well. I took everything apart and painted the brackets while I waited for some new parts to arrive on my door step.
A package from LMC Truck arrived over the weekend which included my new fan belt, a lower radiator hose, and pre-bent vacuum and gasoline lines. Before re-installing the alternator, I took some time at the lathe to make a permanent spacer out of a piece of bar stock. Then I re-installed the alternator and tried the new belt. I was very happy to find that the new 5/8" belt was just the right length for my alternator set up!
I also found a little time to install a PCV valve into the road tube hole. Since the distributor vacuum and gas lines both run up and around the front of the block, I will be running the PCV vacuum line around the back end. The connection at the intake manifold is at the rear face of the manifold, too, so that will be a much cleaner install.
Brian
'83 GMC Sierra 4x4
I like the idea of running the PCV lines behind the engine. I found a PCV factory riser that replaces the road draft tube on eBay last year. The factory routes the hoses over the valve cover and I don’t really like how that looks. Now you’ve got the creative juices flowing and I might consider the behind the engine route instead.
My engine came with the alternator mounted similar to how you mounted yours. Unfortunately, they didn’t fabricate that nice spacer that you turned on a lathe and with just a 3/8” threaded rod, the tension on the pulley from the belt, cocked the alternator. Yours setup looks much better. I ended up replacing it with one of the vendor brackets made just for that purpose, which corrected the issue.
Your making great progress and it won’t be long before you experience that exhilarating feeling when you first “fire her up”. Good Luck!
Phil
Project Journals
This last weekend was pretty exciting for me and moved the project over a major hurdle. Last Friday, with help from my son, we started the rebuilt 235 for the first time. We had an issue with the brand new fuel pump not moving any gas to the carburetor, so I ordered another from NAPA. As it turned out, I had mistakenly installed the pump with the actuating arm behind the cam. Apparently this is not good for the pump. In the meantime, I installed a 12v electric pump in the temporary fuel line to push fuel past the bad pump. That worked well to get the engine running. Then I had to deal with a couple of minor leaks in the old radiator. The engine started with very little prodding and idled very nicely. We then adjusted the carburetor and the timing to get it dialed in nicely. We ran the engine for a good hour and was pleasantly surprised to find only one minor oil leak from the side cover.
Then on Monday, we made my bare chassis "driveable" by temporarily installing the steering gear, and adding a platform and a seat box. We had a good time taking the truck out on its first test drive, albeit at a rather modest pace since the radiator wasn't exactly held firmly in place. All in all it was a great success and I now look forward to moving on to body work and painting!
Brian
'83 GMC Sierra 4x4
Congrats on firing her up! And a second congrats on taking your first ride! It’s a great feeling knowing all that hard work paid off when you hear her run for the first time. Nothing like it. Good work!
Phil
Project Journals
Crusty Old Sarge
Crusty Old Sarge
Very cool! I'm almost to the point of having a drivable chassis, I may steal your plywood idea and add a milk crate as that seems more fitting in my case. grin Great progress.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
It's been a little while since I posted a project update thanks to work getting in the way.
I have managed to clean, repair and paint both of my running boards, and both inner front fenders. I then dove back into completing the repair/rebuild of the steering gear. When I test drove my truck, I used the original drag link (which has a broken spring) temporarily installed on the steering arm (which has a damaged ball stud). At that time, I was waiting on an order which included said replacement ball stud, and a drag link rebuild kit. That took quite a while. The kit was backordered but finally showed up, and the ball stud I ordered was the wrong one. In my defense, the catalog I was ordering from appeared to have a printing problem. I am convinced that the part #s shown for the two steering arm studs were reversed (so I wound up with the ball stud that actually goes on the Pitman arm). The salesperson was very helpful when I called about it. The vendor no longer sold the steering arm stud separately, only in a set with the other stud. Since I already had one, though, the salesperson split up a set and only charged me the difference. It showed up two days later and all was well with the world.
I ordered a rebuild kit for my steering box (one that included a how-to booklet) and once it arrived I read the booklet all the way through, then disassembled the steering box. I was prepared for a bunch of nasty old oil to pour out, but nothing. As you can see in the photo, everything was covered in grease. I'm not sure if that was deliberate, or if the original gear oil had coagulated. After everything was cleaned, I started the rebuild by replacing the bushing and the oil seal in the box. For the Pitman shaft bushing in the side plate, the booklet says it is "impractical to replace the bushing" so you're advised to throw away the whole thing and get a new side plate. I chose to split the old bushing with a burr tool in an end drill. Pressing in the new bushings required making a suitable tool in lathe. The 50-ton cap. press at my shop then promptly died so I was forced to encourage the bushings to go in with a dead blow hammer. With that part done, I moved on to righting a wrong I made wayyyy back when I first removed the steering wheel. At first, I used the wrong type of puller and managed to murder the threads on the end of the shaft. So, I currently have the shaft mounted in the lathe where I will attempt to re-thread the end. More on that when I've actually managed to pull it off.
On a different note, last year I got in touch with a lady who's dad once had a 3/4 ton Chevy from a Union 76 station/car dealership in my town. She didn't have the truck anymore, but did have lots of parts that needed to go. Sadly, there were only two things that fit my truck, but happily, those two things were NOS hub caps for a 3/4 ton truck. I bought them for the cost of two new repro caps, so I was stoked. And very recently, I decided to bite the bullit and get a pair of the Dexstar 16x6 steel wheels to use on the front end of my truck. The 4" backspace means I don't have to use a 1/2" spacer, nor do I have to install longer studs in the hubs. When I received the wheels, I had to set one of the hub caps on to see how it looked. I think they are going to look great on my truck! I have three Chevy steel wheels that will get used on the rear and spare. Next, I will install hub cap clips on four of the wheels then it will be time for paint and new rubber.
Brian
'83 GMC Sierra 4x4
Things have gotten busier at work the past month or so which has kept me away from the project. I have managed to get a couple hours lately stripping paint off of the cab. I bought a small right-angle die grinder and have been using inexpensive 3" dia. stripping and sanding discs from Harbor Freight. The coarse grade discs make quick work of getting down to bare metal. I follow that with a medium grade disc to get anything I missed the first time. Then I use a medium grade sanding disc to smooth out rough areas. This process has uncovered a couple spots of rot that were not previously visible, but I'm not surprised. My son spent a day removing all of the nifty bits from the inside of the cab (gauges, knobs, heater, etc., etc.). Once I get the outside of the cab stripped and primered, I'll move to the inside. I also bought a nice new sand blasting rig (and 25 lbs. of walnut shells) to strip the back side of the dash and other areas where I can't use the discs.
Oh, and there was a small delay in the project, too, when I had to take delivery of a 1928 Chevrolet 1-ton flat bed (LO) that I picked up free at a local yard sale. Now I really need to finish the '51 sooner rather than later!
Brian
'83 GMC Sierra 4x4
Your making good progress. What a nice find on those original GM hub caps.
Nothing like putting the pressure on by getting another project but what a project! A 1928 Chevy 1-ton. Looks like you got your work cut out for you but that will be awesome when it’s done.
Now you need to start another “Project Journal”. Good luck on both projects.
Phil
Project Journals
Crusty Old Sarge
Crusty Old Sarge
I man can never have too many projects. Your cab seem very solid makes me just a little jealous. grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
When I got the '28 I decided I'd better join the VCCA, too, so I'll eventually post project photos and updates on that forum. Since it's a four banger, I don't think a project journal on this forum would be allowed?
Brian
'83 GMC Sierra 4x4
The cab isn't awful, which is a big reason why I chose this truck to purchase. I have to replace the front half of the floor pans, both inner kick panels, a small portion of the lower side of the cowl on the driver's side, and of course both rear lower corners. All of that will be pretty straight forward work. I was really happy that both doors are rot free.
Brian
'83 GMC Sierra 4x4
The rainy days we're experiencing lately have given me good reason to stay in the shop and work on my cab. Much of the cab still had original paint under a coat of red primer (added by a previous owner) which protected the metal pretty well. Other areas were not so nice. I've had to do a lot of sanding to get rid of deep surface rust, and even then I still apply a coat of rust converter to be sure. The new primer on the rear of the cab has made it painfully clear that I will be doing a lot of filler work! The non-original bed that came with the truck does not have a front (end) wall, so it's no surprise that the rear of the cab took a beating.
Today, I stripped the paint off of the firewall and got a really cool surprise. On the driver's side appeared a name written under the original top coat. Since I was using a wire wheel in an electric end motor I was only removing the top coat. Had I been using the more aggressive tools that I have, I would have never seen it! I can only guess that this was put there by an assembly line worker, perhaps to give his or her (female auto workers during the Korean war?) stamp of approval on the cab before it moved on. Has anyone else run across something like this during your project? I plan to preserve this bit of the truck's history by leaving the name exposed (clear coated) through the new paint. I'd love to know more about this person, so I've sent emails to both the GM Heritage Center and the UAW hoping one or both of those groups has access to a list of Flint, MI employees in April, 1951.
Brian
'83 GMC Sierra 4x4
I just read through your build, it truly is a restoration. There was some writing on the firewall on my '47 when I got it 30 years ago, I would have liked to preserve that, but over the years and through several shops, it is long gone. There was also a paper oil change sticker in the door jamb along with a few price gun labels, that would be neat to preserve, but no longer there.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
When I last posted I was getting ready to purchase patch panels for my cab. I was looking forward to digging in to the rotten metal. Before I could order the parts, my son informed me that I needed to wait until after Christmas. Christmas day came and I happily feigned surprise at the new patch panels my wife bought me! Then our weather turned for the worse (tons of snow, then tons of rain) and things at work (protecting our assets from flooding) took precedence over my project. About two weeks ago I was finally able to get going in earnest.
After surveying the damage to the floor pan on the driver's side, I decided I had to remove the seat riser first. It has its own damage (some of it man-made by a previous owner) and working on it up on the welding table would be much easier anyway. The first photo shows the floor pan after removal of the riser. I simply cut the riser off where it joins the back piece, then worked my way around the bottom lip with a very thin chisel and hammer, lifting the edge up to locate the spot welds. I then used a thin cut-off disc to in an electric end motor to slice the welds.
Next, I carefully (or so I thought) measured the new patch panel and marked out the floor where it would be cut out. Finding the point where the rear edge of the new piece would meet the old floor was pretty straightforward, and it turned out well. Not so much going up the toeboard, but more on that a little later.
I should add here that I have to replace the inner kick panel, inner to outer cowl piece (the bottom half of the arc-shaped firewall corner) and a small portion of the bottom of the outer cowl piece. I did not want to cut out all of these pieces right out the gate but did remove just enough of them at the front corner, along the toeboard lip, so I could remove the old floor piece and be able to weld in the new one. The second photo shows that area after surgery, and after I had replaced the end of the cab support rail where the parking brake pivot mounts. This was necessary because after cutting away the inner cowl piece that is spot welded to this rail, the end was pretty thin in spots. The area behind the lower door hinge was also cleaned up, treated with rust converter then shot with primer. At this time I also cut out the bad portion of the lower cowl panel and made new pieces from stock I had in the shop. They will go in later.
With the old floor piece out of the way, I cleaned up the underlying supports, treated with rust converter and spot primed. In the case of the U-shaped horizontal support where the cab mounting bolt goes through to the frame, I gave the inside surfaces a liberal coat of paint since this area will get sealed up by the new floor. I then test fit the new floor panel in place and trimmed where needed to get the correct gap at the rear edge, and to get it to sit down over the cab frame rail along the left edge (I notched the lip along the left edge where it goes by the door pillar). Next, I marked the new panel with a paint pen at all the points where it needed to be drilled for plug welding (third photo - sorry about it being a little out of focus. My iPhone is old and has issues like its user).
A note here that the new patch panels are really nice, but as I've read in many forum posts on various sites, they aren't exact matches and do require some tweaking. In the case of the floor pieces I received, the angle of the toe board is much less than the floor in the cab. I suspect this has to do with shipping issues. In any event, once the new panel was laid in place and clamped in, it was clear that I need to bend the toe board upward to meet the firewall. This is where my careful marking of the floor for cutting went awry, as where you bend the new panel changes the length of the toeboard. In this case, the bend caused the new piece to be a little shorter than I would have liked so the gap ended up being about 3/16" along most of the joint, and a little wider in some spots.
The fourth photo shows the new panel clamped into place ready for welding. All of the plug welds and the seam along the rear part of the floor (which will be under the seat riser) went as planned. The last photo shows the gap at the top edge of the toeboard and my first spot welds to connect it to the firewall. To bridge this much of a gap, I have a small piece of 1/8" thick copper sheet that I hold up to the back side of the gap where I need to weld. To get all the way across the seam, I have to weld about half of it from the inside with my arm around the door pillar, and the rest from the outside, lying on the floor with my arm up through the transmission hole. It's a tedious process but it works. My plan is to not have to do this when I install the new piece in the passenger side of the floor.
The left side inner kick panel is next.
Brian
'83 GMC Sierra 4x4
Nice work Brian! Have you considered cutting a 3/16” strip to fill the gap. That would minimize the shrinkage.
I’ll be doing the same thing in the near future so I’m following your build. Keep up the good work!
Phil
Project Journals
Brian, I am also in a similar position as I have the patch panels (floor, cowl, etc.) but winter has gotten in the way. I will follow along and appreciate the effort it takes to document the activities.
1949/50 3600 Project
Follow in Project Journals
Phil, yes I plan to cut some strips from the piece I took out to fill in the wider gaps, especially towards the middle where the hump begins.
Brian
'83 GMC Sierra 4x4
Thanks, and I will look forward to seeing your progress as well.
Brian
'83 GMC Sierra 4x4
Since my last project update I've finished the installation of the left side floor pan, the left side kick panel, and the left side inner cowl piece. For this post, I'll add a photo of the finished floor pan, and talk about the left kick panel a bit.
The replacement of the left kick panel was pretty straight forward for the most part. I used the old piece as a pattern to get the new one close to where it needed to be, then trimmed it as necessary. Where things didn't go according to Hoyle was with the bottom of the new piece. The frame rail under the cab floor angles inward towards the center of the cab, starting just past the door pillar. Why, I don't know, doesn't the new kick panel piece? I'm sure it's because it's quicker and cheaper to press them out of flat sheet. So needless to say, you have to do some 'cut and paste' work to get the bottom of the panel to meet up with the floor panel. In the photo of the old and new pieces lying on the table, you can see one of the cuts I made at the lower right corner of the new one. I also had to take a very long and thin pie shaped piece out of the bottom, parallel to the bend. This allowed the flange at the bottom to bend and meet the floor. In the third photo you can just see the sliver of light coming up through that cut. Once all of that mess was welded back together, I had to make a funky jigsaw puzzle shaped piece to fill in the gap between the kick panel and the lower left corner of the toeboard where it curves in to meet the floor. There was plenty of grind, fill, grind, fill, etc. And yes, that welding along the door pillar is pretty gnarly. I misjudged the width of the new piece so had to cut little slivers of new metal to place between the new and old, so double the spot welds. I also discovered an interesting thing. I was using a small piece of magnet to hold each sliver in place while I tacked it in. The weld would be very erratic until I removed the magnet, as though the gas shield was turned off. Lots of careful grinding later and it all cleaned up pretty well.
The last photo shows the installed kick panel from the outside. Next up, the inner cowl piece.
Brian
'83 GMC Sierra 4x4
Your experience with the inner cowl panel is pretty what I (and most others who tackled that job) experienced. Mine needed some serious massaging like yours did.
But you got er done. thumbs_up
Get prepared for similar issues with the inner-to-outer cowl piece.
Once the kick panel was done, I moved on to the filler piece between the kick panel and the outer cowl. I had removed the entire thing earlier in order to get the old kick panel out. This also allowed me to clean up the space behind the door pillar. Everything was treated with rust converter then given a coat of grey paint.
I've read a number of times that the filler pieces (what I call the 'inner cowl' pieces) are the worst patch panels in terms of the manufacturers not getting them very close to being a good fit. That's a bit of an understatement. First off, the manufacturers didn't appear to even try to get the top end the same shape as the original. It's also too wide at that end. Next, in the case of my new pieces, the sides bow inward so when you get the piece in place, it doesn't come close to touching the kick panel or the cowl. Lots more 'cut and paste' work!
Since the majority of the original inner cowl piece on my cab is in good shape from about the 1/2 way mark, I decided to cut off the top end and re-use it. The marks on it made by the spot weld cutter were great for getting it right back into the same position. The new piece was then chopped down to match and test fit. The outer side of the new piece was coaxed out with a hammer to get it where it would meet the cowl, but the inner side had to move about 3/8" to meet the kick panel, so I cut it completely off. Once the main portion of the inner cowl piece was tacked in, I fitted the side piece so that it fit snug to the kick panel and tacked it in. All of the pieces were pre-drilled in the appropriate locations for plug welding as needed.
With the inner cowl piece installed, I took some time to clean up the parking brake lever bracket, temporarily bolted it to the toeboard (the original top bolt hole was still there) and used it as a guide to drill out all of the mounting holes.
At this point I decided that another day of sitting and laying on a cold concrete floor wasn't going to happen so I spent some time cleaning up the inside of the firewall and giving it, and the new kick and floor panels and good coat of epoxy primer. The last photo gives a pretty good before-and-after view (comparing the left to the right side).
I have some new metal to install on the lower portion of the outer cowl panel (where the fender mounts), then it's over to the passenger side.
Brian
'83 GMC Sierra 4x4
Thanks! And yes, there were fun times ahead!
Brian
'83 GMC Sierra 4x4
Page 2 of 3 1 2 3
Moderated by  Phak1
