| | | Forums66 Topics128,127 Posts1,056,671 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | Where would I purchase an air filter element for my Lincoln electric Code no. 8810 Model No. Ac -225/ Dc 210/6? Thank you.. | | | | | Joined: Oct 2021 Posts: 6,902 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,902 | Can't you buy it from Lincoln Electric? https://www.lincolnelectric.com/enWhat about an industrial supply house like Grainger or Northern Tool and Equipment?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | The parts list on the site that Otto linked to doesn't even show an air filter. I'd suggest you take your filter down to your local auto parts store and see if they can match it up for you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Put a longer center stud in the carburetor and use this one. The air filter on mine (with a Kohler engine) is 6" OD, 5" ID, and 1 1/2" tall. www.ebay.com/itm/384377618048?Jerry
