0 members (), 89 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1505508 06/16/2023 11:52 AM
This is not another thread about what coating to use. I did have a question about the sheen. Are you guys using a full gloss or a satin finish on your clear coats. FYI - I will be using a product a guy at a wood shop told me he uses on everything exposed to the weather and it works great. TotalBoat Marine Varnish.
Dave from Northern Kentucky
My 54 3100
I used the gloss marine varnish on my bed. Held up well so far.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Is that yellow pine?
1950 Chevrolet 3100 (Ol' Roy)
Insomniac
Insomniac
Satin finish on maple. Lots of compliments.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I used a deck stain tinted black for an original look. The guy at the paint store said people in Fairbanks are using it on decks with good results. It's an oil based stain. The only issue is drying time. I had to spray it in order to get it to dry. If I brushed it on it took forever to dry.
Sure is. Long leaf yellow pine. Some I salvaged from the depths.
This one is axe cut.
~ BD.
The Mar-K company that makes the bed parts, has quite a detailed article about the research they did on bed finishes. It's really good. You can find it on their website.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
dgrinnan #1505594 06/16/2023 10:11 PM
If you want the bed-wood painted black:
Mar-K:
POR-15 Rust Preventative Paint with Behr black glossy enamel:
(paint all 6 sides of each board)
Three coats of POR-15 Rust Preventative Paint applied 3 hours apart and the first coat of Behr applied 3 hours after the last coat of POR-15 Rust Preventative Paint.
Two more coats of Behr applied the next day.
o This appears to be a durable black paint system.
o Possible slight reduction of gloss since the initial application in July.
o You can see the grain pattern of the wood but the boards are fully sealed
and there are no flaws in the coating.
I have used this technique on two pine-wood beds:
- 1954/55 GMC 25' COE bed
- 1954 3100 Chevrolet 1/2 ton bed
dgrinnan #1505611 06/17/2023 12:08 AM
I read the Mar-K study 6 years ago and did the black paint. I have mixed feelings about the results. It was on yellow pine. This time I am going with ash (just as hard and straight grained as white oak but half the price). I am going with a medium color stain and multiple coats of marine spar varnish. Just trying to decide gloss or satin.
My 54 3100
Yep, The POR -15 for black is good. Top coat with
Rustoleum. I did the plywood bottom and top with
that on my panel. The clear marine varnish was brushed on 8 coats. One a day.
~ BD.
Donald S.
Donald S.
I did mine with cypress wood, minwax ebony stain and 3 coats of urethane gloss finish on both sides
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
dgrinnan #1505766 06/18/2023 11:41 AM
Cypress would be my next choice. Nice!
~ BD.
dgrinnan #1506371 06/23/2023 12:14 AM
Gloss for me.
Red oak walnut stain gloss varnish
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Donald S.
Donald S.
Skooter,
Nice look especially the black contrast against the red and the light stain👍
1953 Chevy 5-window
Gloss on mine. Hickory wood.
1947 3600 Chevy
Free OSB from somebody on Nextdoor / random leftover paint.
