2 members (Gdads51, MNSmith), 80 guests, and 5 robots.
Topics128,181
Posts1,057,152
Members48,464
Page 2 of 3 1 2 3
T-Doug #1506611 06/24/2023 4:37 PM
Yes, just be sure to mark the bearing caps so they can be reassembled correctly. When the housing was manufactured, the caps were bolted on, and then the final machining was done, like main bearings on an engine block. It's important to keep that relationship correct to make sure the holes stay round and in proper alignment.
T-Doug #1506615 06/24/2023 4:58 PM
Left side out and washed. Broken lock washer on the bottom bolt.
Seems like the whole assembly will come out when I get right side off. We’ll see.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1506619 06/24/2023 5:20 PM
Dog doesn't seem to be much help.
T-Doug #1506631 06/24/2023 6:38 PM
This was a lot heavier than I remember when I was younger.
Got it cleaned enough that it’s not slippery
Marked the cap bearing retainers and both top bolts.
Now I would guess the next step is to take the bolts out of the ring gear. That should let me get to the last two bearings. Looks like I’m in the market for a press. I’m assuming they are pressed out and in.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506640 06/24/2023 7:37 PM
Yeah, you'll need a bearing puller to get the differential bearings off the carrier. Similar to THIS. Also either a press or a 3-jaw puller.
Why did you mark the bolts? Their position isn't critical.
Question: If that spider gear you found on the bottom of the case wasn't split in two, how did it come out since the shaft was intact?
T-Doug #1506655 06/24/2023 8:45 PM
Don't take the ring gear bolts out yet- - - -unless there's some damage I'm not seeing in your picture, I don't see any serious damage to the ring gear. Also, if you take the locking tabs off the adjuster nuts, the bearing caps will come off and on a lot easier. The gear backlash is going to have to be adjusted on reassembly, so keeping the adjusting nuts in their original position isn't necessary, or desirable. If the ring and pinion gears don't have teeth missing or bad score marks, you can probably reassemble the thing with different spider and axle gears and a pivot shaft and drive on- - - -at least temporarily. Then you can make an informed decision about swapping to a different gear ratio at your convenience. Even if the gears howl a little at highway speed, earplugs are cheaper than rear end parts. Those third members are as tough as woodpecker lips- - - -just get the adjustments right as you reassemble things.
T-Doug #1506659 06/24/2023 9:02 PM
I'll put up a close up showing a couple broken teeth on the ring gear... the pinion has rough spot on one tooth
that brings up what gear ratio to look for... hmm let me put it this way.. what ratios are available.. so far I've seen 3.55:1 and 3.90:1
assuming ring and pinion R&R is the next step to drain tranny and start taking the forward part of the torque tube off the transmission.. Its a 4 speed btw..
I'm feeling good just getting the sucker apart now it seems to get harder with the pinion removal..
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506686 06/24/2023 11:25 PM
klhansen I don't know how that gear got out but maybe that area of the carrier that was chipped out my be where it went.. possible it didn't come out until I started trying to move the truck.. just don't know.
Hotrod.. the pivot pin looks perfect.. no scrapes or gouges..
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506693 06/25/2023 12:03 AM
If that spider gear isn't split in two, I'm going to guess a previous owner didn't get the shaft through it when the rear axle was last assembled. It likely wound up between the ring and pinion and caused the rest of the destruction.
BTW, your truck has 3.90:1 rear end ratio. See the 39-10 markings on the pinion. Also, that's the stock ratio for a 54 1/2 ton. I don't know if the 3.55:1 ratio gear set is available for the '54 models. The '54 half tons also have a different differential case than the earlier 1/2 ton trucks, so the available 3.55:1 R&P set may not fit.
Look for the casting numbers on your differential case on the attached pic.
T-Doug #1506699 06/25/2023 12:24 AM
Oh. The dog is my motivation coach.
From another discussion the 3:55 won’t fit.
I just ordered a used good condition 3:90 from a 54 3100 on eBay. Fingers crossed.
I had also found and ordered a set of spider gears from eBay that also came out of a 54 3100 so we’ll just have to wait and see.
Now to figure out how to lower and pull the torque tube to get to the pinion. From the service manual it looked complicated
I’m also going to either have to get a couple bigger jack stands or another floor jack if I need to be on the frame rather than the axle.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506703 06/25/2023 1:24 AM
That sounds like a good enough excuse to me for buying new tools.
1950 Chevrolet 3100 (Ol' Roy)
T-Doug #1506718 06/25/2023 5:26 AM
He doesn't look to be setting a very good example. I might be napping right along side him.
Removing the u-joint isn't that bad a job. Be sure to stick a jack stand under the torque tube to catch it when you get the u-joint loose. Don't ask how I know about that. wink
T-Doug #1506755 06/25/2023 4:19 PM
I’m still a little unsure of the process. See if I have this right.
Reposition jack stands to frame
Drain transmission
Take bolts out of rear transmission housing
Pull housing to the rear?
Then what. Looking at service manual wasn’t clear.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506771 06/25/2023 6:22 PM
You have to unbolt the u-joint bell from the transmission, slide it back, split the u-joint and remove the half that slips on the driveshaft. Then position the driveshaft below the transmission (I don't recall if a '54 has a rear transmission support crossmember like my '51 does, but if so, that will have to be removed first) and then unbolt the differential housing from the banjo (axle housing), and pull the whole thing FORWARD and out. I'd recommend some ratchet straps positioned under the differential housing and the torque tube to catch it as it comes out. It's heavy.
T-Doug #1506804 06/25/2023 11:57 PM
Off to harbor freight tomorrow morning to get some bigger jack stands. The ones I have won’t reach the frame. Always something in the way of progress.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1506812 06/26/2023 1:12 AM
Check Harbor Freight and Walmart.
T-Doug #1507036 06/27/2023 11:58 PM
Should have read your post sooner tclederman.. after I went to harbor freight I saw the same one at wally world for $10 less delivered.. oh well.. I don't like Walmart much anyway. smile
Another question for you pros... what is a good sae 90 oil for the trans and pumpkin.. I planned on using Mobil one 75-90..
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507037 06/28/2023 12:02 AM
Modern gear oil is fine for the rear axle, but you should use either mineral oil or gear oil rated GL-4 or lower for the transmission. GL-5 has sulfur in it that messes up the brass in the synchronizers.
T-Doug #1507100 06/28/2023 5:05 PM
After looking at all the bearings and such I think someone rebuilt the rear end and for whatever reason didn’t put that last spider gear in place. All the bearings and races show no wear at all. Same for axle bearings. The guy I bought this truck from I suspect rebuilt it and on first drive it tore up. That’s only thing that makes any sense.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507110 06/28/2023 6:53 PM
It's possible to dislodge a spider gear while sliding the pivot pin into place- - - -usually the one opposite the pivot shaft lock pin hole. One of my students at the Tennessee state trade school where I was teaching did that, and also locked things up on a test drive. A rear end will work (for a short time) with only one spider gear in place.
T-Doug #1507125 06/28/2023 7:56 PM
The spider gears have to to be placed directly opposite each other between the side gears, then rolled into position. I don't think there's room for one to be dislodged if they were lined up properly with the pin. The assembler just plain messed up installing them. I don't think there's much room for the loose spider to lay in the bottom of the case. It'll be sucked in between the ring and pinion in pretty short order.
T-Doug #1507140 06/28/2023 10:04 PM
Not sure the pin would go entirely in if the gear wasn’t centered
1949 gmc 1-ton
T-Doug #1507248 06/29/2023 9:28 PM
Is there a trick to getting the ring gear off the housing. Bolts are out a used rubber mallet then ball peen firmly but lightly around the edges. I put some PB on it and let it sit while I ask questions.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507293 06/30/2023 2:04 AM
Riding in the Passing Lane
Use a drift & that ball peen hammer. Hammer the back edge of the gear as you go around to keep it even. It will come off with enough persuasion. You cannot dent the gear as it is hard steel.
George
1972 Chevy c10 Cheyenne Super
T-Doug #1507306 06/30/2023 4:10 AM
Thread a few bolts back into the ring gear and leave a 1/8 inch space instead of tightening them fully. Hammer on the bolt heads. When the ring gear starts to move, back the bolts out a few threads and hit them again. Once it separates from the carrier little it will get easier to move.
T-Doug #1507350 06/30/2023 4:22 PM
Got it off.. used a 1x4 and that ball peen and beat it evenly.. took a bit to get it going and had to use a little more force toward the end to get it past the carrier housing.. tight fit..
waiting on new ring gear to show up.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507362 06/30/2023 5:47 PM
When the "new" gears arrive, cut the heads off a couple of long bolts to guide the ring gear into place as you install it onto the carrier. Put the ring gear onto the grate of a charcoal grill for a few minutes to expand the hole before you install it and it will drop right onto the room temperature carrier.
Hotrod Lincoln #1507395 06/30/2023 10:51 PM
Good idea Hotrod. I’ve got a gas grill so I’ll bake it a little. Already picked up 3 bolts to use as guides. Saw that on a YouTube video. Ring gear is sitting at local usps since yesterday. Patience working overtime.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507500 07/01/2023 8:58 PM
Well the mystery deepens.. Got the ring and pinion gears in today and was doing a little more cleaning of the pumpkin and guess what.. found a hole in the upper side of the casing.. and its a old hole.. no fresh marks of violent gears and teeth flying around... so.. that makes me thing someone did rebuild the rear end at some point in the past and not only left a hole but likely a gear in the bottom.. which would have been covered by the oil..
So I cleaned up the hole and will bring out the JB weld again.. I know, I know.. but consider this out on the farm and you want to get it back to work. smile.. on the cheap I should add... there will be a price to pay down the road I'm sure..
Its been too hot after about 10:00 here to do anything in the garage and I've been catching up on yard work the last 4 days.. Hopefully by next week I'll have everything back together and ready to try moving it again... and discover the next problem.. lol
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507504 07/01/2023 9:54 PM
How about a picture of the hole?
BC
1960 C60 pasture art
T-Doug #1507516 07/02/2023 12:09 AM
By the casing, do you mean the axle housing? Yeah, a picture would sure help. There should be a vent fitting on the axle housing, 1/8" NPT tapping. On earlier axles it's on the passenger side axle tube a bit left of the banjo section. If that's what you mean, don't JB weld it shut. If you don't have a vent, you'll get oil pushed out the axle seals onto the brake shoes. Not good.
T-Doug #1507587 07/02/2023 2:48 PM
The hole is at 2:00. Second picture shows the crack. I didn’t take a picture from the outside.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507626 07/02/2023 6:18 PM
Yeah, that hole is likely from that loose spider gear getting wedged between the ring gear and housing. It might have been the cause of the rest of the gear damage when it locked up.
T-Doug #1507644 07/02/2023 9:45 PM
If you want to stay with the torque tube setup, it looks like you're going to need a different housing. Even if the hole can be brazed up from the outside, I don't think I'd trust the integrity of the machining any more. This would be a good time to convert to a later model housing with the open driveline, and a corresponding transmission. The 55-59 3.90 ratio center section with the open driveshaft will bolt into your existing banjo housing, but you'll need to figure out a way to make the pivoting spring mounts rigid if you do that. Welding those rubber bushing pivots is a real PITA!
T-Doug #1507886 07/05/2023 1:31 AM
After working on it all day off and on I finally got the ring gear on. Yea
Now the part I don’t like. Going tomorrow to get a torque wrench. $$$ for a good one but I try to not skimp on tools
Now need to find the torque to use. Anyone have that handy.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1507894 07/05/2023 2:26 AM
Ring gear bolts - 40-60 ft-lb
Others you might need:
Bearing cap bolts - 115-135 ft-lb
Pinion bearing retaining bolts - 85-95 ft-lb
Pinion Shaft bearing Nut - 200-240 ft-lb
U-joint yoke ball retainer bolts - 8-12 ft-lb
U-joint Yoke Attaching Bolt - 15-20 ft-lb
T-Doug #1507899 07/05/2023 3:14 AM
Thanks klhansen
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508108 07/06/2023 5:40 PM
Ok. Can’t get everything to stay in place while putting the carrier back in. Fought with it all morning so far. Any sage advice someone can give would be appreciated
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508401 07/08/2023 11:49 PM
I finally got the carrier in and the side gears. But I can’t get the ring gear to rotate to get the spider gears in.
It’s in neutral btw. When I got the truck he had the top of the transmission off to the side. I just slid it over and dropped it down. Is it possible he didn’t have yokes in the right place and it has a gear engaged. I can move the shifter and it feels like it goes into gear.
Does anyone have a picture of where those yokes are supposed to be on the gears.
Thanks for any help.
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1508472 07/09/2023 12:19 PM
You were able to rotate the original ring gear to get it apart so it doesn't seem likely that the problem is in the transmission. Is it possible that in the process of getting the carrier in place that you have the ring gear mesh with the pinion gear jammed such that they can not move relative to each other?
1949/50 3600 Project
Follow in Project Journals
Page 2 of 3 1 2 3
