2 members (DES57, 1 invisible), 142 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
#1506136 06/21/2023 2:28 AM
1950 Chevy 3100 216 3 Speed.
I’m trying to remove the radio push buttons. I thought they just pushed on. I want to remove them and they won’t budge. Before I pull to hard I want another opinion.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
2 Offline
They pull off
Just pull more
You won’t damage anything the plastic will yield before metal bits damage
The Metal can be straitened and reformed worst case
-s
2 Offline
I should add
This can be done on a button for button basis with the radio out and disassembled so you aren’t pulling from a complete radio in dash situation
But it’s the same force
I usually take the radio completely apart on the bench before I attempt to pull the knobs so that I can put a clamp behind each and slowly pry each off in a controlled way
Thank you for the advice. Every project is always more difficult than you expect.
Darren
Moderated by  truckernix
