0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1504392 06/09/2023 11:43 AM
I have a 1966-70 model 250 engine in my 1965 C10 without the head and I don't have the head bolts either.
I want to remove the block and need to know what size and thread of eyelet bolts I need to get to lift it with.
As always thanks for your help!
1965 Chevy C10 Longbed Fleetside
WarEagle1,
A search of GMpartswiki provided the screenshot below which has the info you need to get some threaded eyebolts.
The actual head bolt part number is listed in the center for you to use when searching to replace your missing head bolts.
Make sure you get good quality eye bolts as unrated bolts could fail catastrophically (safety first, right)! thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Serious on this: been there, done that, my buddy's finger didn't grow back.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Thanks very much for the info and I will be careful
I use a piece of angle iron bolted to the block and a chain shackle attached through a hole drilled in the angle iron. No need for an eye bolt of possibly questionable strength. Use Grade 5 or 8 bolts to attach the angle iron firmly to the block.
If you can weld you can build your own lifting bolts, Hotrod Lincoln's idea works good too. I've done lifting some huge loads with even small sections of 1/2 thick angle iron.
I have 2 methods depending on the job.
1) a selection of lifting eye bolts from McMaster Carr and 2) 10K lifting straps for oddball stuff.
As others have said, never, ever use big box or hardware store eyebolts.
1955 Chevy 2nd Series 3100 Stepside, 235cid
AD Addict & Tinkerer
The only eyebolts that should be used are shoulded eyebolts as they permit a side load. A 1/2”-13 shouldered eyebolt is rated for 2,600 lbs per McMaster-Carr website. Here is [LINK].
Phil
Project Journals
Stovebolt Gallery Forum
War Eagle1 A lot of electric motors will have their own forged eye bolts .I save these bigger ones to use like you need,gotta watch for metrics though they'll be on offshore stuff. I also saved axle bearing retaining rings brazed on an appropriate sized bolt and moved blocks around that way. If you don't trust bronze low-hi (7018) arc weld them on there. Several of those on the window sill !!
Thanks again for all the advice. One question: Hotrod are you saying a single length of angle iron? bolted crossways?
Or use lifting straps cradled around the bottom of the motor
(not me, or anyone I know - just an image from the 'net')
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission
6 Bolt disc conversion with dual master/vacuum booster
12V alternator conversion.
235 engine in waiting grin
Hmmmmm- - - - -a Model A with an overhead valve conversion cylinder head, or maybe that's a Mercruiser 4 cylinder? That's got to be a first for Stovebolt!
LOL!
I know it's not a Stovebolt 6 - just an illustration of the process
