| | | Forums66 Topics128,069 Posts1,055,884 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | Have 51 3 speed manual transmission, cant get the drain plug to stop leaking? Tried everything, permatex, regular Teflon, gas and oil Teflon, even swapped the plugs from drain and fill , nothing. ?
1953 with a 216
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like you may have a crack in the housing. A pipe plug should not leak if tightened down with a sealer. Clean it off good & take a close look at it.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | That's a simple pipe thread. Use an NPT tap (I think it's 1/2" NPT) to clean up the threads and put a 1/2" to 3/8" brass reducer bushing into the case with red LocTite if necessary to get a new thread for a plug to fit. The transmission doesn't know or care what size drain hole it has. Make sure someone hasn't overtightened the plug and cracked the case. Jerry
1953 with a 216
