Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jay d, Southerntruck, 1 invisible), 168 guests, and 6 robots.
Topics128,281
Posts1,058,464
Members48,490
Page 2 of 2 1 2
Also, if you add a keep alive circuit, make sure it is not connected back into the main circuit or you can backdraw through it when the switch is off.
Most radios these days have separate BATT and IGN connections, so you don't need to worry about it there. For custom installations, just be careful.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Good advice. That would be a sure way to smoke a circuit the first time you forget to thru the main switch on before hitting the starter. If there's not a separate connection to your radio that needs constant power, a diode in the normal power circuit to the radio could be installed.
I had an undergrad (EE) student burn my electric humvee down by doing that. I would have thought it would be a lesson learned until he did it a second time...
The school wouldn't let me fail him, so he graduated and went to work for Dodge...
eeeek
eeeek
That explains some things. not me
AD Addict & Tinkerer
You could install a small inline fuse on the bypass circuit so if you forgot the main switch, you will only blow the fuse.
Phil
Project Journals
Stovebolt Gallery Forum
I never put an interrupter switch on a battery ground circuit for just that reason. Killing the power to the battery cable that supplies the starter will usually interrupt the voltage supply to the dash and ignition switch as well. Run an independent small diameter wire (with maybe a 5 amp fuse) to whatever needs a few milliamps of constant current to keep its memory functioning.
Sir Searchalot
Sir Searchalot
I suggest we cut this off. This is as simple as it gets to wire.
Interesting. What would we cut off?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Moderator, Electrical Bay
I agree with Bartamos. Let's move on to other things.
~ Jon
Page 2 of 2 1 2
