| | | Forums66 Topics128,080 Posts1,056,288 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 102 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 102 | Hey everyone,
I'm new to this forum. I inherited my grandfather's 1952 Chevy 1/2 ton pickup! I've been driving it around for the last two years and trying to figure out how to work on it myself. All of this is new to me but it is A LOT of fun! I have a question about the transmission oil. The manual calls for 1 1/2 pints of 90 weight gear oil to be put in the transmission fill hole. I have seen some who also put oil into the ball housing/universal joint filler plug hole. Manual says this isn't necessary because that joint gets its lubrication from the transmission. Does it help to put a few ounces in the universal joint filler hole? Will this overfill the transmission? If so, is there any harm in having a little more in there?
Any help on this topic will be greatly appreciated!
Thanks, Pastor Matt
52 Chevy 3100
Jesus said to him, "I am the way, the truth, and the life. No one comes to the Father except through Me." -John 14:6
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | I let the tranny oil seep down into the ball joint. Regarding overfilling the tranny, assuming you have a SM420, I fill mine via the side plug until the oil gets to about 1/2"-1" below that hole.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | If the housing gets overfilled the lube will seep out of the input shaft area and contaminate the clutch. If there's wear in the driveshaft bushing just behind the universal joint ball, the lube can seep down the torque tube and overfill the rear end, resulting in leakage at the rear axle bearings and brake contamination. Since the spinning gears in the trans splash lube all over inside the case, if you can touch the oil through the fill hole in the side there's plenty of lube in the case. A slightly low oil level is better than over full. Don't use fancy synthetic lubes in a stovebolt transmission- - - -plain old 90 weight mineral oil is all it needs. Jerry
52 Chevy 3100
| | | | | Joined: Jan 2022 Posts: 2,468 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,468 | Short answer to the question "Can you overfill transmission?" is "Not for long."
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Sep 2009 Posts: 5,940 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,940 | Pastor Matt, Just a note to say "Welcome to the Stovebolt Community" since these are your very first couple of posts. We would love to see some pictures and learn more about you and your truck that you've "...been driving it around for the last two years...".  Perhaps you would re-introduce yourself and your truck in our Welcome Centre? You also might like to drop a note in The Southern Bolters forum and say hello to other Bolters near you. Catch you in the various forums as your need for info takes you. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2023 Posts: 102 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 102 | HA! That's what I want to avoid.
52 Chevy 3100
| | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | I have seen some who also put oil into the ball housing/universal joint filler plug hole. Manual says this isn't necessary because that joint gets its lubrication from the transmission. Does it help to put a few ounces in the universal joint filler hole? If you look at Page 4-10 of the service manual (the rear axle section), it says to put 1/2 pint of transmission lubricant thru the hole at the rear of the transmission. It says nothing about lubricating the u-joint in the transmission and u-joint sections.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
