| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 10 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 10 | Does anyone know it the original wheel color for the 1951 GMC 3/4 ton pickup matched the body color or was it white, black, etc. thanks | | | | | Joined: Oct 2021 Posts: 6,842 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,842 | Virtually every one I've seen that hasn't been rodded or modded has body color wheels.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | Lots of trucks, especially the heavier models had black wheels. I just took a look at a sales brochure I downloaded (too big to attach) and there were pickups with black wheels, suburbans and panels with body color wheels. Pick your flavor and go with it. Unless your truck is some strange color, black wheels will look fine, but If you want body color, that's good as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | bobbynudd My Chevy is body color with a pinstripe kind of a cream color. | | |
