1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1503493 06/03/2023 11:20 PM
While I’m waiting for another trash I have time to look at the turn signals.
I’ve got a harness end and the leads out of the column.
This what I have from the harness end that are labeled.
White ~ brake sw
Green ~ right rear turn
Yellow ~ left rear turn
Purple ~ turn signal feed
Brown ~ turn sw hazard
Dk blue ~ right front turn
Lt blue _ left front turn
Black ~ horn
Column side
White
Purple
Pink
Dk blue
Yellow
Lt blue
Black
Any suggestions on which go where. The column side is a new cup and turn signal but came with no directions on what goes where.
Thanks for any input.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1503496 06/03/2023 11:32 PM
Sir Searchalot
Sir Searchalot
The column side is a new cup and turn signal. The word turn signal describes a function, not a component, I believe you are saying a new "cup" bell and a new turn signal switch. ??
You will need to determine what each wire on the switch does. As you are asking. You already know what the harness wires do.
Before answering, I need to know a few things. I think I know the answers but I want to be sure.
1. Which bundle is from the new switch? The one with connector or the one without?
2. Whichever one it is, it seems they are both new. Harness is new. Switch is new. So why is there a connector shown? Was this connector pre wired or did you do it or what?
3. Can you give the vendor and part number of the new switch?
4. Did this 54 already have a turnsignal set up on column? and need some new parts? or all new addition.
5. I believe 54 was the first year for a factory turn signals option.
6. Do you know how to do a continuity test if necessary?
7. You may want to read the tip section as a preparation. Cletis has a tip in there.
As you can see with electrical questions, I take things slow.
bartamos #1503503 06/03/2023 11:58 PM
They are both new.
The connector side is from the new harness kit and pre wired.
The kit is from American Autowire kit no. 510004.
It came with the turn signal hub so likely factory. I tried to recondition the old one but it proved to rusty to save so ordered a new turn signal hub assembly from Classic Parts.
I’m pretty cautious with electrical also which is why I haven’t connected yet. Been busy on mechanical and fuel issues anyway.
My plan is to cut the wires and put on bullet connectors. Then use jumpers to connect and test each one to verify the right connections. Then push them together and heat shrink each.
Thanks for the feedback bartamos
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1503506 06/04/2023 12:36 AM
Sir Searchalot
Sir Searchalot
Most likely:
Column side
White.........................BRAKE SW
Purple (should be called VIO) .................RR TURN/STOP
Pink............LR TURN/STOP
Dk blue...........................RF
Yellow.........FLASHER
Lt blue....................LF
Black......HORN
BRN on harness not used (Hazard)
T-Doug #1503627 06/04/2023 9:22 PM
Thanks bartamos.. I'll be hooking them up sometime this week and let you know how it went..
1954 Chevy 3100
Montgomery, AL
In Project Journals
T-Doug #1503688 06/05/2023 4:06 AM
Sir Searchalot
Sir Searchalot
thumbs_up
T-Doug #1504167 06/07/2023 11:40 PM
Update on turn signals.
This is what I ended up with calling out the steering harness first.
White to white
Purple to purple
Pink to yellow
Dk blue to Dk blue
Yellow to green
Lt blue to Lt blue
Black to black
Now the weird side.
Right side works fine.
Left side only rear works. No power to it. Hmm
When the signal arm is all the way up the right side work. Ok
Back to neutral and left rear works
All the way down and all are off
Got me scratching my head. Any ideas
1954 Chevy 3100
Montgomery, AL
In Project Journals
